Best Power Steering Gear Box RHD? - Defender Source
Old May 30th, 2012, 01:19 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
I have come to the conclusion that I need to replace my gear box to fix the play in my steering wheel. I will also be replacing the drop arm with attached ball joint. I will try to post a video ASAP of the play, but I believe its my probably not the PanHard Bushings.
Can someone please tell me who makes the best pwer steering gear box and where to find it for the cheapest. My truck is a Right Hand Drive.
Thanks in advance!
Old May 30th, 2012, 01:40 PM
Rosproline157
Matt Oaks
1992 Defender 90
I do have power steering currently, It leaks really bad too! I need to change it do to the play in lower shaft of the unit and the drop arm. Do you any contact information for Meridian?
Do you have power steering now? If so, you should consider contacting Meridian about rebuilding your box. If not, maybe source on from the UK.
-Jeff
Old May 30th, 2012, 03:07 PM
http://www.meridianautoparts.com/
rhd
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Defender RHD Power Steering Box John_Karlsson Wanted 7 September 27th, 2010 01:40 PM
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
» Defender Registry
NEV
wanabewheelin
Pancho
LPP
Add your Defender
