Best paint? - Defender Source
Old September 13th, 2010, 09:02 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Best paint?
Big day as I dropped off the first set of parts to get color on them.
Truck is going back willow green which is a metallic base coat/clear coat.
I tried searching but could not find anything saying what is the best paint to use in terms of durability etc...
Painter says DUPONT but thought I would ask here to see what you all thought.
TYler
Old September 13th, 2010, 10:12 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I'm a fan of PPG.
Old September 13th, 2010, 10:25 PM
Originally Posted by Tyler Wirken View Post
clear coat.
TYler
I thought only beluga black got the clear coat?
Old September 13th, 2010, 11:47 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Well if you are going to respray the truck why not correct what LR didn't do and put a clearcoat on.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 14th, 2010, 12:04 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Why do you think clearcoat is an improvement?
Old September 14th, 2010, 02:32 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
harder to scratch, but also harder to touch up/rub out
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old September 14th, 2010, 02:57 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
There are a number of NAS clear coat colors:
Beluga Black, Willow Green, British Racing Green, Arizona Blue (and a few I likely forgot).
PPG and DuPont both have goods and bads about them.
You should go with what your painter is used to using and make sure he has a DuPont or PPG certification for the paint warranty.
Email:
Old September 14th, 2010, 03:48 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Can you get a color equivalent to the Willow Green without the clearcoat?
Tyler, I think you plan on getting the 110 out to play from time to time....would it be easier to shine up with a single stage (if that's even the correct terminology)?
...thinking out loud again....
Oh, and congrats on the progress!
KAA
Old September 14th, 2010, 04:46 PM
LRover's Avatar
LRover
J. Michael McCaig
Having a Beluga Black 90, I can tell you that when the clear coat gets the slightest scratch, it really shows up. Compunding is a real pain because unlike non-clear coat, getting a scratch out isn't easy because if you don't do it right, it dulls the finish.
Old September 15th, 2010, 10:20 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks for all the help. Yes I do plan on using the truck but think I will stick to clear coat instead of single stage as I want it to match the rest of the parts as good as possible. Thanks Mike for the info I really appreciate it. I will check into all of that stuff as well as keep you all updated the best I can.
Old September 15th, 2010, 10:41 AM
UnfrozenCaveman
Keith Armstrong
Various
..think I will stick to clear coat instead of single stage as I want it to match the rest of the parts as good as possible.
Ah, sure then. For some reason I thought the entire thing was being painted.
KAA
Old September 15th, 2010, 08:35 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
My paint guy uses PPG which is what I think Land Rover used for the Beluga Black.
If I remember right the paint on my D110 is:
1 coat primer
2 coats base
1 coat base/clear
1 coat clear
baked in between at 125 degrees
I think he also did a light sand/buffing between each coat.
ID:	31129   Click image for larger version
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
paint
touch up paint januconn92 Defender Technical Discussions 3 January 30th, 2007 10:01 AM
Paint Color/ Paint Code little black duck Defender Technical Discussions 3 March 16th, 2005 05:30 PM
Wheelwell paint rustydefender Defender Technical Discussions 6 February 9th, 2005 02:08 PM
Paint Code? Trigger Defender Technical Discussions 4 June 17th, 2004 01:45 PM
Paint a fiberglass hardtop? roverboy Defender Technical Discussions 5 December 12th, 2003 09:52 AM
