Best oil filter for 3.5 V8? - Defender Source
Old May 3rd, 2014, 09:50 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
My oil pressure light came on the other day, as I was pulling into the garage. My driveway is pretty steep & I come in at a good angle, so I figured that may be the cause. Shut the engine down, checked the oil level. Read a tad high, but real clean.
I started it again yesterday & drove around the block- no oil light (except briefly at startup). Did some research. Turns out I had better pull the oil pan & make sure the oil pickup pipe/screen are clean & tight. Do I still need to check this, even though it seemed fine last time?
Sounds like Valvoline VR1 20W50 is the best oil to use?
What is the best filter?
Paul.
P.S. Yes, I searched & Googled.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 3rd, 2014, 09:59 AM
What oil is in it now?
I always just use a Genuine filter, but I'm there's probably something better out there.
Old May 3rd, 2014, 10:06 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Mobil Super 10W40.
No dealer here. Is the 3.9/4.0/4.6 filter the same as the 3.5? I can look it up if so.
Old May 3rd, 2014, 10:09 AM
There are two genuine filters a short and a long. With filters I'm of the impression bigger is better. No idea on aftermarket but Wix/Napa Gold, Bosch,Purolator, Mann, Fram are all readily available. Tdi's and V8's all use the same filters.
Old May 3rd, 2014, 10:10 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
ERR3440, same as the others.
Old May 3rd, 2014, 10:39 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Tom/Antichrist posted a big study on all the major oil filters a while back-either here or dweb...
Rent my
Old May 3rd, 2014, 10:48 AM
NAPA1452 is the big one, NAPA1068 is the smaller of the two. WIX has the same part number.
Old May 3rd, 2014, 10:51 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks guys. Is Valvoline VR1 20W50 the best oil to use?
Old May 3rd, 2014, 10:56 AM
My guess is that your oil light came on because of the weight oil you are using. Your engine probably has a good bit of wear and could use a thicker oil such as 20w50.
Old May 3rd, 2014, 10:59 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks Jimmy!
Old May 3rd, 2014, 11:13 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I have always had good luck with the Napa/Wix. I would never use a fram to many cases of them causing oil pressure issues.
I use 15w40 shell Rotella
Unknown Author
716-898-8153
Old May 3rd, 2014, 11:34 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
http://www.bullittarchive.com/5000/5...arison_Kit.pdf
Rent my
Old May 3rd, 2014, 02:13 PM
Paul,
Was your idle really low? At very low idle the light will come on especially when the oil is hot (and thin because of that). Another thing to check is to smell the oil and see if it smells like gasoline (from a leaking carb). That will thin it out and cause low pressure too. Check these before pulling the oil pan and cleaning the pick up. If you do pull the pan, replace the cross seals too.
I use genuine oil filters and 5w40 rotella in my rover engines these days.
Old May 3rd, 2014, 03:28 PM
That sounds kind of risky to me since you could disturb an otherwise non leaking rear main seal.
Old May 3rd, 2014, 11:13 PM
My oil always wreaks of fuel, it's taking a toll on my classic.
Old May 3rd, 2014, 11:17 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
A Rover whisperer who works at a dealership in VA other than Richmond told me these old rear main seals hardly ever leak...it's always the crucifixes!
Rent my
Old May 3rd, 2014, 11:20 PM
I believe that, but to replace them you have to remove the rear main bearing cap which could easily disturb the rear main seal. Unless it was a very bad leak, I wouldn't mess with them personally.
Old May 4th, 2014, 12:17 AM
Wuss. I have never crawled under a 20 year old rover and not seen a cross seal leak (unless they were replaced) and I have yet to see an actual rear main leak.
Old May 4th, 2014, 12:41 AM
ezzzzzzz
Mark Garrenton
Swap out the oil pressure sender first and see if the problem goes away. It's a cheap part readily available.
Old May 4th, 2014, 07:04 AM
and always leaking
v8
2.5 NA/2.5TD Fuel Filter head with NIB Filter. hillstrubl For Sale - Parts 3 June 1st, 2013 11:46 AM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
TDI sediment filter - OEM is Delphi CAV filter? jaherring Defender Technical Discussions 2 October 25th, 2010 03:33 PM
300Tdi oil filter? artm Defender Technical Discussions 1 April 19th, 2005 06:30 AM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
