Best oil filter for 3.5 V8? - Page 2 - Defender Source
Old May 4th, 2014, 06:00 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Update:
Took her for a quick run on the freeway this morning. Oil light went out shortly after starting. Ran fine, except it shuddered & shook like crazy at ~50mph (much smoother around 70). I will get the wheels checked for balance next week.
Brought it back, drained the oil, pulled the sump cover. Oil pickup pipe was secure, and the mesh was clean;
Took the opportunity to clean up the sump cover & give it a coat of paint (Wal Mart hi-temp barbecue paint, which I used to use on Porsche exhaust tips);
I filled the filter (Napa gold 1452) and filler her up with Valvoline VR1 20W50 racing oil.
I will drive her to the office a few times this week & see if the light comes back on, but right now unless the sensor/wire is bad, I'm stumped. As was mentioned, it could have been the oil I was using.
I plan to drive her to Portland in a couple of weeks to get some work done by Doug Shipman. We'll see if she makes the 4.5 hour trip!
Thanks again for all the help.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 4th, 2014, 11:32 PM
Paul,
Re: vibes at 50mph.
Check the torque on the suspension bolts and make sure no bushings are shot, especially the panhard rod bushes.
Old May 5th, 2014, 10:17 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
filters
I like the Mahle OC261, good German made (last time I ordered) filter at a decent price from AB, Trevor and others.
As far as oil, i'd consider M1 15w-50 if you are going thicker, gets you the thicker viscosity plus better cool weather pumping than a conventional 20w-50. The V1 syn may also be a good choice.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old May 5th, 2014, 03:11 PM
the NAPA is made right here in America
Old May 5th, 2014, 03:31 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Originally Posted by evilfij View Post
Paul,
Re: vibes at 50mph.
Everything seems tight! I will get the wheel balance checked shortly to eliminate that being a factor.
w
Mahle make great filters, I always used them on my Porsches. I just couldn't get one in time. I'll see if there is any difference with the different oil in her- drove it to work today & no oil light!
Old May 5th, 2014, 11:34 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Update on the 50mph shimmy:
One of the front wheels had lost its weights. They fixed it but it's still not as smooth as I had hoped.
I'll see what Doug Shipman has to say when I drop her off on Friday...
v8
2.5 NA/2.5TD Fuel Filter head with NIB Filter. hillstrubl For Sale - Parts 3 June 1st, 2013 11:46 AM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
TDI sediment filter - OEM is Delphi CAV filter? jaherring Defender Technical Discussions 2 October 25th, 2010 03:33 PM
300Tdi oil filter? artm Defender Technical Discussions 1 April 19th, 2005 06:30 AM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
