Best lube for... head bolts ? - Defender Source
Old March 22nd, 2013, 09:28 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
LR manual say use engine oil.
What about anti-seize compound ?
Or Lithium based grease ?
Thoughts ?
- Charles Eames
Old March 22nd, 2013, 09:31 AM
Don't use anti-seize. I always use engine oil or Wurth HHS spray.
Old March 22nd, 2013, 09:35 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
If the manual says engine oil, why wouldnt you use engine oil? Its not exactly hard to find.
Old March 22nd, 2013, 09:38 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Sounds logical, but I don't trust LR vehicles neither LR manuals
- Charles Eames
Old March 22nd, 2013, 09:39 AM
Bacon grease
Old March 22nd, 2013, 09:43 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by o2batsea View Post
Bacon grease
You know we are pork specialists down here ?
Our north coast is the birth place of the buccaneers, best pig cookers this side of the globe.
- Charles Eames
Old March 22nd, 2013, 09:48 AM
You gotta go with what you know JD
Old March 22nd, 2013, 09:52 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
The book says engine oil cause thats how they measured the torque for the given bolt when tightening down. Use anything else and your torque could be off. Just make sure to clean out the holes. Qtips, alchol, air compressor, bolt with a notch/groove cut into it either/or works.
Old March 22nd, 2013, 09:57 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I screwed by hand each bolt dry first, to feel the resistance, only one is a little tacky. Every bolt hole was plugged during block cleaning and scrapping, so they're pretty clean and shinny.
- Charles Eames
Old March 22nd, 2013, 02:19 PM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
My manual says:
29. Lubricate threads of bolts with light oil and fit to positions shown below. (Fit air cleaner mounting bracket at positions 6 and 14).
I dunno, I don't think in engine oil when I read that. More like gun oil.
Old March 22nd, 2013, 02:29 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by Santiago Montenegr View Post
My manual says:
I had 3in1 oil in my list also, I like the smell of it
- Charles Eames
Old March 22nd, 2013, 02:33 PM
Torque specs with anti-seize vary depending on composition and will almost certainly differ from equivalent torque with engine oil.
the point is to apply the correct amount of torque.
Old March 22nd, 2013, 02:39 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
like i always say do it right the first time ......ARP ultra-torque lube only!
http://youtu.be/6-XXVk_vwKw
No Mall crawler here
Old March 22nd, 2013, 06:22 PM
ARP lube or motor oil
Old March 22nd, 2013, 08:11 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
ARP lube...watch the video
Old April 2nd, 2013, 11:36 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The torquing sequence for post 94 V8 heads indicates that the first step is to reach 20 NM, which is about 15 FP I believe. Most torque wrenchs start at 20 FP, how do you guys get those 15 FP, needle torque wrench?
- Charles Eames
Old April 2nd, 2013, 11:43 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Using new factory bolts.. 15 ftlbs is hand tight anyway but a good 3/8 tourque wrench goes to 5 ftlbs
Studs require different torque value as stated by manufacture of stud
Old April 2nd, 2013, 12:13 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
What do you mean by hand tight ? you have to use a socket anyway on bolts 9 and 7, no fingers will fit there.
- Charles Eames
Old April 8th, 2013, 02:55 PM
andyrad
Andy Radlgruber
None.
Use engine oil. The block does not get so hot that the bolts would sieze, it's not a gas turbine. And make sure you go light on the oil and that the holes are empty of liquid so you dont create a hydraulic fracture when you tighten the bolts. You just need a bit of slippy to allow the torque to be as accurate as possible.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old April 8th, 2013, 07:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I used motor oil, right head is bolted and torqued to specs, some bolts feel harder than other, in particular for the last 90.
- Charles Eames
bolts
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Removing Seat Track Bolts! JimC Defender Technical Discussions 5 November 5th, 2004 03:15 AM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
