Best Long Travel 4" Suspension kit? Defender 110 on 35's - Defender Source
Old October 3rd, 2015, 05:07 AM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Talking Best Long Travel 4" Suspension kit? Defender 110 on 35's
Hello,
This fall I plan to build up a 2001 Defender 110 TD5.
I am looking for your recommended suspension for a 4 inch or so lift to fit up to 35" tires (yes I know bigger than most recommend). .
I have had the complete Old Man Emu 2" before it was great with 32's, excellent stability and very trail worthy. Now I want a long travel set up, remote res and bump stops etc. Even a combination of kits?
Is this a good contender, perhaps switch the shocks for Fox Remotes? I would love to hear your ideas!
Mega Sport 11 inch travel Competition kit (110/130)
Old October 3rd, 2015, 11:41 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
35" tires will fit well with a 3" lift... Rte has a decent combo of parts that will do that for you.... Lucky 8 springs will get you 4" on a rover but they, (the rovers) are quite tippy so most as you said wouldn't want to go there. I run 35s with 14" sb bilsteins... Remember to get the proper valving on the shocks. Rockware makes decent rear shock hoops and can build you a set to fit longer shocks... Be ready to deal with likely vibration issues at 3" and probably much worse at 4". Click image for larger version
Old October 3rd, 2015, 11:51 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I ran 35" tires on a NAS 90 with a 2" lift. Cut the flares and install longer bump-stops. There is so much room inside the wheel wells you could probably get away with 35's with no lift.
Old October 3rd, 2015, 11:56 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Take the flares off and you basically can with the right (skinny) tire and wheel offset... Only thing is, if you actually wheel it, they will rub like crazy when you articulate.... I had 33" tires (255/85/16) on my truck with a 2" ome lift and my rear tire rubbed at full articulation... That's a 10.5 tire, which is difficult and expensive to find in 35s.
Old October 3rd, 2015, 12:14 PM
rovertrader's Avatar
rovertrader
Dale
35/10.50-16 SSR tires on Wolfs with 2" lift and extended bump stops, no issues except trimming flairs at bottoms. Also, I tried a 285/75-18 with an adaptor to run D-II 18" wheels, and similar results. It can be done with 2" lift, and the end result is much better IMHO. I also run the Rockware hoops which are sweet. When locked F&R, and this setup, you can do most any trail in the country- shy of KOH, which can still be done albeit a little carnage- same with Las Cruces. But no issues on Blanca and such...
However, for grins and giggles I love 37's on my HCPU ;-)
Old October 3rd, 2015, 01:40 PM
rovertrader
Dale
Here just with 2" lift and 35's with offset wheels:
Old October 19th, 2015, 08:12 AM
WestCoastRover
Jeff
2000 TD5
Thanks for the help guys! Looks like I'll try to get 3" springs from Lucky 8, and run 34" Toyos.
As for the kit, Has anyone had experience with the Terrafirma Mega Sport 11" kit with hydraulic bump stops?
I will build the 2001 TD5 110 in Europe before shipping to Canada.
Here is the Kit:
http://www.lrparts.net/terrafirma-me...-110-130.html#
Old October 19th, 2015, 09:28 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by WestCoastRover View Post
Thanks for the help guys! Looks like I'll try to get 3" springs from Lucky 8, and run 34" Toyos. As for the kit, Has anyone had experience with the Terrafirma Mega Sport 11" kit with hydraulic bump stops? I will build the 2001 TD5 110 in Europe before shipping to Canada. Here is the Kit: http://www.lrparts.net/terrafirma-me...-110-130.html#
Curious about the 34" Toyos - any information on them?
Old October 19th, 2015, 09:44 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Here is the look in question:
ID:	132748   Click image for larger version
Old October 24th, 2015, 09:46 AM
WestCoastRover
Jeff
2000 TD5
I guess I'll get a good idea first hand as I Picked up this 99 TD5 today in Spain! 4.5" Lift, with F.O.A. Remote res shocks and 315/75r16 (34.6x12.5r16") tires, even ARB lockers :D Canada bound in a few days. Didn't feel any high speed shakes, definitely a bit "boat like" on the corners, but wow does it take suck those bumps up. It has a remapped ECU and straight pipe.. which I think really helped balance the power loss from the tire ratio and weight, definitely worth upgrade IMO. I still think I will go 3" and 34" on my 110 with all proper radius arms, remotes, bump stops etc.
Old October 24th, 2015, 11:59 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Most 315/75/16's seem to be closer to 34" than 35" anyway.
Old October 24th, 2015, 02:09 PM
That truck is definitely my style
Old October 25th, 2015, 09:43 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Originally Posted by Arcadeus View Post
35" tires will fit well with a 3" lift... Rte has a decent combo of parts that will do that for you.... Lucky 8 springs will get you 4" on a rover but they, (the rovers) are quite tippy so most as you said wouldn't want to go there. I run 35s with 14" sb bilsteins... Remember to get the proper valving on the shocks. Rockware makes decent rear shock hoops and can build you a set to fit longer shocks... Be ready to deal with likely vibration issues at 3" and probably much worse at 4". Attachment 131402
What exact size are those tires? 315/75 16? Also how wide are the wheels as well?
I love that look.
Old October 25th, 2015, 11:40 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Wheels are walker evans... 17" x 8.5" ... Tires are bfg mk2 35x12.5r17 ... Think the backspace is 3.5 if I remember.
Old October 26th, 2015, 12:17 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Very nice.... Even got a D44 front bumper & 8274, great find
Old October 26th, 2015, 01:47 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks. I bet the 17" wheels make the 35's look different.
Love that look.
Old October 27th, 2015, 08:41 AM
WestCoastRover
Jeff
2000 TD5
I could not find the Defender bolt Pattern on the Walker Evans website? Did you have to have the wheels specially made? I would be interested in buying a set.
110, defender, defender 110, kit
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
long travel shock mounts.. the rover shop For Sale - Parts 12 July 18th, 2012 08:13 PM
OME Suspension/Spring "A" and "B" handing question. Daringer Defender Technical Discussions 9 January 18th, 2012 10:23 AM
Suspension +2" travel? headdamage Defender Technical Discussions 0 December 5th, 2006 12:24 PM
Desert Rover Rear Long Travel Shock Kit kiphartzell Wanted 0 March 17th, 2005 10:21 AM
