Best Ignition Wires? - Defender Source
Old February 20th, 2004, 10:32 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
"Hotwires"? http://www.streetbeatcustoms.com/nol1450801.html
What's the BEST of the BEST?
THanks...
Old February 21st, 2004, 12:48 AM
Magnecor. I think any performace gains from a rover V8 are neglible
Old February 21st, 2004, 01:45 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I agree, and I agree. I run Magnecor's in two of my rigs and they are great--in that they deliver sparks to the engine. I still go slow up hills--don't ever expect changing wires to give you much if any of a noticably increase in a D90 except over wires that not functioning properly. I just purchased a set of "racing" red magnecors off e-bay (used, they were Hren's) and replaced my perfectly good stock wires (which I had to switch to my RRC) and did not notice the slightest differenct. FYI/FWIW
Old February 21st, 2004, 09:39 PM
OCD90's Avatar
OCD90
Torrence
1997 Hardtop
I use the Magnecor Blue wires, as they're the biggest to fit (barely) in the stock looms. When I switched to new plugs and the Magnecors, I noticed a definite improvement in idle smoothness and "felt" like I had a slightly discernable power increase, however small. It's hard to say if it was plugs or wires, but I'm happy.
Old February 22nd, 2004, 04:06 AM
wicks's Avatar
wicks
Wicks
Thanks guys. I'll get some Magnacors.
What type of plugs are the defacto "bestest of the bestest"?
Old February 22nd, 2004, 04:10 AM
i heared stocker were best plugs, i think they are champion.....
in addition the Bosch 4 platnum
www.roverconnection.com
Old February 22nd, 2004, 01:31 PM
scrover
Steve Cooper
93 RRC LWB
Wicks, I recently went with Magnecor 8.5s and stock Champions. I was previously using Bosch wires and Platinum plugs. The idle seems more stable and performance is as good as it's ever been. Could be my imagination, but it seems like a good combination.
BTW, the 8.5 wires fit the stock wire retainers just fine.
SC
Old February 22nd, 2004, 10:10 PM
Mike M's Avatar
Mike M
Mike McC
1990 Range Rover County
Magnacor 8.5 and NGK.
The wire kit should come with custom wire retainers from Magnacor. At least my three sets did.
I had Bosh plugs but they would never last long. So I went with NGK. Great plugs. They have lasted longer than Bosh ever did.
New ignition wires 93-95 3.9 evilfij For Sale - Parts 0 November 6th, 2009 10:46 PM
Spark Plug/ ignition wires mdmccallum Defender Technical Discussions 3 September 1st, 2005 11:48 AM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
