Best fluid for the R380? - Defender Source
Old April 4th, 2006, 03:58 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
So I did a search and read various posts, but never came up with a diffinitive answer. What is the best fluid to use in the R380 tranny?
I just got my tranny rebuilt for the second time this year (second gear synchro was COMPLETELY stripped, both times), and I want to make sure that I don`t have to do this a 3rd time any time soon. Any input as far as fluids go would be appreciated. The builder just put ATF fluid in it. Is ATF sufficient? Any input would be appreciated.
Old April 4th, 2006, 07:29 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
ATF is what LR recommends.. I have heard the Redline MTL is the way to go though. THat is what is going in mine next change...
Legend in My Own Mind.
Old April 4th, 2006, 10:36 AM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Yeah, this is talked about in another thread somewhere. I noticed a huge difference when I switched to MTL. It seems that the ATF is just too thin for the synchros IMO.
Old April 4th, 2006, 02:58 PM
LR sells their own version of ATF which supposedly works great. I have Redline MTL in mine, but i'd be curious to hear what Rob D has to say on the matter.
Old April 4th, 2006, 03:59 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Redline's MTL worked wonders for my R380. I like that you can basically get it anywhere. I searched the fourm back when i was trying to make the same decision and learned there are fluids marketed only in the UK but I didn't like the fact that getting it when i needed it might be an issue.
my2cents
Old April 4th, 2006, 04:14 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
On Rob D's advice I switched to Royal Purple. Can't notice a difference from MTL but rob is the man. Plus royal purple is a little cheeper than MTL at summit
Old April 4th, 2006, 07:41 PM
cbass's Avatar
cbass
Bradlee Duncan
Yeah, Royal Purple is good stuff too, I recommend it also. I have seen the results from MTL though and I'm sure RP is similar. Both very much better than ATF, IMO
Old April 4th, 2006, 08:03 PM
Redline MTL here even my mother noticed the difference
Old April 5th, 2006, 12:26 AM
oldscratchggf
nate
95 d90
Redline MTL it`ll be. Thanks guys
Old April 7th, 2006, 09:02 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Exclamation
Before you do anything, have a look here:
http://www.defendersource.com/forum/...ead.php?t=3182
and here:
http://www.landroverfaq.com/viewtopi...ighlight=mtf94
and here:
http://www.caltex.com.au/products_oi...?id=107&area=1
I recommend you use MTF94 (Texaco product), LR ref. Nš STC5157 & STC5158
- Charles Eames
r380
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
