Best Battery for the Defender??? - Defender Source
Old February 8th, 2012, 01:49 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
I need a new battery and am wondering if I can go bigger? My truck is very stock, but was wondering if people are using more power than just the suggested battery. I am not planning on going to a dual set up at this time.
Any of your thoughts on this are much appreciated.
1997 D90 ST #1615
I have not been asked once if my 90 was a Jeep after I installed my new decal!
Old February 8th, 2012, 03:43 PM
Naplm00
Matthew
Opinion:
Biggest baddest single battery you can buy that will fit in the stock battery box is the Sears diehard platinum PM-1 marine battery.
http://www.sears.com/shc/s/p_10153_12605_02850131000P'
you will need to make a new hold down,.
I chose the marine one because it has the very convenient lugs and threaded terminals.
The only downside is that the comparable group 34 diehard platinum has a better warranty but is smaller in size and this thing weighs 75 lb
Old February 8th, 2012, 03:53 PM
Whatever was speced in the bosch P38a fits and keep in mind the stock battery was pretty huge too (just slightly smaller).
Old February 8th, 2012, 04:42 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
I like the marine battery idea, maybe my slow drain won't eat this battery as fast. And its in stock less than 30 miles from my house. How did you handle the tie down or do you just try not to hit speed bumps at 70mph?
1997 D90 ST #1615
Old February 8th, 2012, 04:48 PM
Naplm00
Matthew
I drilled 2 holes in a piece of steel bar I bought while i was at sears, then i used a 5 dollar battery hold down L bolt kit, drilled new holes in the base of the battery tray and snugged it up.
http://www.amazon.com/Westward-1EFZ8...sim_sbs_auto_7
in my truck the battery was almost touching the bottom of the seat base so it would have def shorted out if something wasn't done
Old February 8th, 2012, 05:00 PM
johndoe007's Avatar
johndoe007
Patrick
1997 D90 ST #1615
Were you able to use the stock battery compartment metal slide cover with this battery? or did you need the extra room and have to remove it?
1997 D90 ST #1615
Old February 8th, 2012, 05:03 PM
Odyssey, Die Hard and I have had great luck with Optima or Excide gel cell. If you truck sits alot, pick up a $20 Craftsman battery tender, it comes with 3 different attachments. One you can connect to the battery and leave the dongle hanging out, so it is easy to connect.
Old February 8th, 2012, 05:14 PM
Naplm00
Matthew
it just fits with the stock cover, about 2in of clearance
battery
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Galvanized Defender Battery Box & Tool Box James Pierce For Sale - Parts 9 September 3rd, 2010 10:23 AM
Best battery for Defender? wicks Defender Technical Discussions 22 August 11th, 2008 03:48 PM
Another "My Defender won't start" question MiniGuy Defender Technical Discussions 4 December 28th, 2005 12:51 PM
