Best battery for Defender? - Page 2 - Defender Source
Old August 11th, 2008, 02:40 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Two optima yellows here. Stay away from reds, they are different animals.
http://i115.photobucket.com/albums/n...twoyellows.jpg
Old August 11th, 2008, 03:14 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
If your run your batteries in series like that, don't you have to switch the charging terminals regularly if your not running a dual charger type system? I'd like to figure out a way to add two batteries to my D90 inexpensively. Thanks
Robert Deniro
Old August 11th, 2008, 03:48 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Not that I am aware of. It acts like one big battery and both batteries charge at the same time. I have been running dual batteries like this for years and never had to switch anything.
It is essentially one big battery. They problem is that if you run it all the way down, then you don't have a back up. I did it this way because I wanted to have plenty of juice to run an Engle for a full day or more with the car off, and still be able to crank up. I wasn't sure if I could accomplish this on one battery alone. I just have to watch it and not let it run for longer than two or three days (which would never happen anyway since it would only be 1 night before cranking up and driving again). I plan on adding a digital voltmeter like ECR did on the dormobile project as soon as I find out who makes a nice compact unit.
battery
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Sealed battery? OCD90 Defender Technical Discussions 4 December 22nd, 2003 01:43 PM
