best battery for cold starting 200 tdi - Defender Source
Old October 31st, 2012, 01:47 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
I've looked around old posts but haven't really found exactly the info I'm looking for.
I haven't had the need to look at the battery so with the cold weather looming I finally thought to check out what I had. The battery has been working just fine but I want to make sure it will start if it gets to be a proper cold winter. Last year in NH was very warm so it wasn't a concern.
After looking I was a bit surprised to find a GM battery with a piece of blue tape that someone wrote "good" on it. And nothing holding it in place.
So, I'm looking for advice on the best battery for cold starting a diesel after it's been sitting at work all day. I don't have any fancy lighting or a winch (yet). Also, what group size should it be and any mounting ideas. (I did see some good mounting threads, any favorites?)
Thanks!
Old October 31st, 2012, 01:53 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The closer you can get to 1200 CCA the better, though close to 1000 CCA is aceptable. Many people are buying the Sears Platinum series.
Old October 31st, 2012, 02:11 PM
I like the interstate battery for a NAS D90. The one for a bosch p38a fits but is a lot more money and does not fit quite as well but it is bigger.
Old October 31st, 2012, 03:50 PM
First thing is to have the current battery load tested. Usually they can do that at any local auto parts store for free. That will tell you if there are any cells that are bad or not performing. A flooded lead/acid battery should be good even for low temps as long as it is in good condition.
Batteries are made in two types; starting and deep cycle. Think of them as a sprinter and a marathoner, respectively. A deep cycle battery can be used for starting, but a starting can't be used for deep cycling.
You can tell the difference simply by trying to lift them. The same group size will weigh quite a bit differently, with the deep cycle being much much heavier due to the thick plates of lead. Start batteries have grid plates with lots of surface area so that they can release lots of energy quickly, thus their plates are lighter. Also, deep cycle batteries will be made in far fewer group sizes; usually only in 24, 31, 4D and 8D.
Most people would agree that the new development of absorbed glass mat (AGM) has far exceeded the performance of the old flooded lead acid battery. They come in both starting and deep cycle and even in a combination of the two. They last longer, hold a charge better and allow more flexible mounting options than flooded cell batteries. They cost more, but outlive flooded cells by at least three times so end up being cheaper in the long run. I highly recommend this type of battery especially in cold climate conditions.
I think you can fit a Group 24 battery, which shares the same footprint as a Group 34 but is taller.
The most popular brands are Optima (spiral), Odyssey (traditional plate), Deka (ditto) and Sears Die Hard. My personal choice is the Deka made by East Penn in good old Pennsyltucky.
Old October 31st, 2012, 03:53 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I have been running the Napa Commercial batteries and they are working very well.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old October 31st, 2012, 03:59 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Same here
Old October 31st, 2012, 08:01 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
You have to go with Odyssey or the Die Hard Platinum. They are both produced by Enersys. Enersys is a huge Defender Supporter!!!!! Plus if you go Odyssey and shoot me some photos I will send you some free gear!!!! I too have a 200tdi. PM me.
battery, start, starting, tdi
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
200 tdi defender for trade pendy Defender Technical Discussions 4 May 1st, 2012 11:26 PM
Cold Weather Starting the 200 TDI; Trials and Tribulations from Colorado paluskat Defender Technical Discussions 9 February 5th, 2011 03:58 PM
200 tdi not starting bcourtney Defender Technical Discussions 3 July 21st, 2010 04:58 AM
