Best Battery Disconnect Switch? - Defender Source
Old September 28th, 2009, 03:05 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Question Best Battery Disconnect Switch?
Hi all - long time no see! Wondering what the cleanest battery disconnect switch is that would switch inside the box, but operated from the other side beneath the seat. My truck keeps murdering batteries sitting in the garage for extended periods.
Thanks for any pointers!
Old September 28th, 2009, 03:30 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For my winch I use a Cole Hersee 2000A.
But if it's just for your starting battery and you don't have high current drains like you would with a winch, something in the 100-200amp continuous duty would be fine. Like a Cole Hersee M290-01, brass case, silver contacts with o-ring seal in the saft. 1000A intermittent, 125A continuous.
But really the best thing is to correct the source of your drain.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 28th, 2009, 03:37 PM
One off of a NAS 110.
Old September 28th, 2009, 03:45 PM
wicks's Avatar
wicks
Wicks
How do I find the source of the drain?
Old September 28th, 2009, 04:39 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
My D came with a marine switch mounted on the front of the drivers seat box. Push in and turn it to shut off the battery.
To find a drain on other cars, I have hooked up a multi-meter measuring milli-amps between one of the battery cables and the battery, and took a reading. I think anything over like 40 mA is bad. I then had someone pull fuses until the mA measured dropped. That will at least point you in the direction. This is a decent link:
http://www.aa1car.com/library/battery_runs_down.htm
bill
Bill
Old September 28th, 2009, 05:49 PM
Search for the drain issue. Door/key chimer, clock and a couple other things have come up as the culprit.
Old September 28th, 2009, 05:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
I had a cd player that was continuously on in my 110 that killed multiple batteries for the previous owner. I sat in the car with the key out and could hear the disc cartridge running. Took it out and never had another issue.
battery, disco, switch
FS Hella Battery Cutoff Switch Stmpede For Sale - Parts 27 December 2nd, 2009 11:23 PM
Remote Battery Disconnect and Terminals wcampbel@nas.edu Defender Technical Discussions 6 August 21st, 2008 04:18 PM
Battery disconnect location Emerson00 Defender Technical Discussions 2 November 30th, 2007 10:10 PM
