Best available motor mounts for V8 - Defender Source
Old May 7th, 2013, 11:18 PM
cgalpin managed to break a couple bolts off my motor mounts so I will need some new ones (no big deal as they were 20 years old).
I am looking for some recommendations. I hope to do some wheeling with this thing so I would like some better than stock ones and I am willing to live with more vibes if need be.
So, what do you recommend? QT? something else?
Old May 7th, 2013, 11:22 PM
Ron, do the Qt...I did my homework, and then installed them. They're awesome. Only downside - as someone else said - is that once you put them in you'll never have to put new ones in again .
------ Follow up post added May 7th, 2013 11:23 PM ------
Discussed here:
http://www.defendersource.com/forum/...t+motor+mounts
Old May 7th, 2013, 11:28 PM
Where did you get them? Lucky8?
Old May 7th, 2013, 11:32 PM
I actually got mine from Randy Williams....he had them in stock at the time.
Old May 8th, 2013, 09:31 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Jag V12 motor mounts. $15 from RockAuto.
Part # JLM1010
Old May 8th, 2013, 09:52 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Discussed here:
Any noticeable increase in vibrations with those?
Semper Fi!
Old May 8th, 2013, 09:54 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
I had the QT mounts in a Discovery with a built 4.6. Even with a rough idle/lopey cam I really liked the more directly connected feeling the engine had to the chassis. It would probably be more pronounced in a 90 but I wouldn't hesitate to buy them again. Great product, great results.
Old May 8th, 2013, 10:21 AM
Negative.
Old May 8th, 2013, 10:45 AM
I need to remember to either throw mine in my troy box or install them
Originally Posted by pendy
I'm here for the D's
Old May 8th, 2013, 05:06 PM
Ive done Jaguar V12 mounts on a RRC, they are much more beefy and cheap.
Old May 8th, 2013, 07:02 PM
For something that is wheeled heavily I would go with the QT mounts, but there is definitely a noticeable difference in noise/vibration. For most people I would probably recommend the JAg V12 mounts.
motor, v8
