Best ARB Compressor installation location? - Page 2 - Defender Source
Old January 1st, 2015, 01:11 PM
Originally Posted by jmx View Post
I've a '93 D110 which already has an AC Compressor installed. Is it possible to install a second one for the purpose of tools/airing tires/etc.?
jmx...this is a real old thread revival from a newb!! Whom actually lives close to our monthly Happy Hour spot - you need to get your arse to this in January so we can drool over your NAS D110, and give you some in person answers!
It also shows that newbs are capable of using the search function. I like this guy already!
Old January 1st, 2015, 01:28 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
The short answer is yes...but as Jonesy recommended you should have some in person discussions to get the full details!
Old January 1st, 2015, 01:39 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I wonder what silverlight ended up doing?
Welcome jmx!
Old January 3rd, 2015, 05:49 PM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
As regards to the Powertank option, I have had one for several years and enjoyed the ability to move it between my Disco 1 and D-110, as needed. Here is a picture of the tank in its current location at the back of the 110. From this position, the hose reaches all four tires without removing the tank. I got it from the local Off Road Warehouse. I refill it at an Airgas office near my home.
Have fun with your truck!
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old January 17th, 2015, 11:47 AM
jmx
John Cross
1993/D110 NAS
I was trying to make the 1.15 session but work gets in the way.
Really appreciate the responses. Will look at a future date for an in person consultation as I work on cleaning up the d110. Thanks.
Old February 14th, 2015, 06:53 PM
Since this was brought back from the way back machine - anyone make a bracket to fit a single carb compressor in the engine compartment? - otherwise i'll just figure it out.
95' D90 - daily driver..
Old February 15th, 2015, 08:39 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
What specific compressor are you trying to mount?
Old February 15th, 2015, 11:04 AM
ckma12 the single cylinder model
preferably i would like it under the hood rather than the seat box.
Old February 15th, 2015, 01:25 PM
Ignotus
gene
1960 109, w/200TDI
Welcome jmx!
In post #15 Silverlight says he went with a Powertank set up, 2011.
Gene
1960 109
1960 88 Ignotus
Blog;
Old February 16th, 2015, 10:24 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Most folks I have seen that put them under the hood ended up making a simple bracket to put the compressor behind the headlight on the LH side. Not a lot of real estate otherwise...I opted for an engine mounted York and then have a Viair unit under the RH seat box as a backup.
Old February 16th, 2015, 10:56 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Robert, I gave my machinist some plans and he made me one out of stainless.
That being said, Jeff could likely make you something pretty sweet as well.
Old February 16th, 2015, 09:35 PM
Mr Payne and i are working on another item at present - i may be able to fab this or failing that Jeff or brewie i'm sure could help.
the left front area on my truck is getting a little crowded with winch solenoid, and some relays - so probably need to redo it anyway and have a bracket that can mount all this stuff.
Old February 16th, 2015, 10:12 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
I felt like sharing this bit from my '95 D90. I was at your point a few years back and made the decision to enlarge the stow box under the passenger seat. I removed the box, extra panel that narrowed the opening, and made a mock-up. My goal was to get as much room as possible and carry a manifold for locker solenoid's, one gallon tank, and the compressor. Extra storage would be good too. Another thought was to keep weight down and also not go below original floor line of OE box. Anyway I managed to pull it off. An airline of 1/2" stainless tubing runs from the tank along top of the frame to the rt. side headlight bezel. The storage allows for hose, gauge, gloves and few other goods. Hope this helps.
ID:	113955   Click image for larger version
Old February 16th, 2015, 10:14 PM
well, that's pretty clean!
Old February 16th, 2015, 10:19 PM
cascade90's Avatar
cascade90
Mason Worley
Thanks, I like simplicity. I like 'em clean but I love gettin 'em dirty. With all my mods I just figure I'm takin out the little factory defects.
compressor, installation
Pic's needed - Recovery point location on ARB bumpers rlynch356 Defender Technical Discussions 14 October 20th, 2016 08:35 AM
ARB Air Pump mounting Location????? jetmech Defender Technical Discussions 7 December 18th, 2009 09:06 PM
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
