Bent Rockware tie rod & drag link: fix or replace? - Defender Source
Old April 15th, 2013, 03:46 PM
sro
Sam Odio
2008 LR2
Yesterday while offroading I bent a rockware tie rod and drag link. Was going about 20MPH on a graded dirt road and hit a ditch that came out of nowhere. Thankfully everyone is okay.
I'm wondering if I should fix them (bend them back?) or replace them? I think if I'm going to replace them I'd have to buy these: http://landroverparts.roversnorth.co...e=TF250&type=0 as I need a set before Saturday and I can't find anything locally.
Old April 15th, 2013, 03:54 PM
RoversNorth
RN
2012 Land Rover Defender
Unfortunately those are backordered from our supplier Terrafirma, we are trying to get them here as soon as possible.
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old April 15th, 2013, 04:13 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I bent a HD rod and straightened it by putting it in the fork of a tree and used a winch. NOTE: THIS IS DANGEROUS AND BE CAREFUL IF YOU TRY IT! that being said, it worked great and I drove it the 200 miles home (towing a trailer) and then for a couple more weeks until I pulled the trigger on a RT high clearance bar. You should check with Keith to see if he has any laying around before he closes up shop or check with Justin as he may have them in stock.
Old April 15th, 2013, 04:38 PM
sro
Sam Odio
2008 LR2
Okay, well I just ordered a replacement Rockware drag link and tie rod. I figure if bending it back isn't a long term fix, better to just fix it right. I'm hoping they can ship it out today since the defender is currently stuck on the trail.
I wonder if I should've gotten the ball joints as well, even though they didn't look damaged?
Old April 15th, 2013, 05:00 PM
You can bend them back and drive off the trail as long as they are not kinked.
Old April 15th, 2013, 05:37 PM
psykokid
Jake
1997 Disco
Yup, they can be bent back into shape to make it off the trail. Baldewin taco'd his pretty good back in december on a run, bent it back into shape using the trailer wiring hole in his rear cross member to hold it. Measured toe with a bit of strap and got it close enough to make the 3 hour drive back home:
Old April 15th, 2013, 08:09 PM
A highlight jack handle makes a nice temporary sleeve.
ac
Equipe Drakken Anyone? pcscharfe Misc. Chit-Chat 26 April 27th, 2009 09:01 PM
Pan Hard Bar & drag link TDI Guy Wanted 2 October 24th, 2008 05:39 PM
Drag link end @ steering drop arm Uncle Douglas Wanted 3 August 10th, 2008 11:14 PM
HD Tie Rod dchapman For Sale - Parts 4 July 6th, 2007 04:46 PM
RRC HD Safarigard tie Rod TDI Guy For Sale - Parts 1 June 20th, 2006 07:15 AM
