Benefit/drawbacks of raised exhaust? - Defender Source
Old July 15th, 2012, 07:50 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Hey Folks,
I understand the purpose of the Snorkel/raised air-intake, but rarely see anyone with the raised exhaust. I've operated in HMMWVs with raised exhaust, and came across the photo of the 130 with raised exhaust and got curious. Whats the benefit? Is it necessary for deep fording? Any effects from lengthening the distance the exhaust must travel before escaping?
Dave
ID:	54268   Click image for larger version
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old July 15th, 2012, 08:38 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Increased exhaust length = increased back pressure. If you stall while in the deep a raised exhaust will keep the water from backfilling the exhaust.
1970 SIIA 88, Sold
Old July 15th, 2012, 08:47 PM
ontheway's Avatar
ontheway
Dave
OK - so increased back-pressure adds undue strain on the engine because it makes it more difficult for each cylinder to expel exhaust... am I correct here?
Old July 15th, 2012, 09:17 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
yes and no....some engines are designed with a certain amount of back pressure. The two reasons I see for doing a high exhaust is so that you don't suck water up the pipe on a water crossing the other is to get the fumes up out of the way. People do not like following behind my diesel on the trails because of the fumes. If you get them up higher it isn't as bad.
Land Rover 110
Old July 15th, 2012, 10:00 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I saw a jeep years ago at Paragon with a raised exhaust, but he had a lever in the cockpit (it was a TJ based buggy) that directed it through either sidepipes (normally) or the raised bit (water crossings). Seemed more complicated that it needed to be but I guess a cool proof of concept?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old July 15th, 2012, 10:57 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I could see the advantage of having a raised exhaust in Colorado if I had a smoker!
Old July 16th, 2012, 06:51 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I've considered it, but ended up raising it about 6" and running it out the side of the rear quarter.
Semper Fi!
Old July 16th, 2012, 09:17 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
At a certain point, a raised exhaust will be negated by the river's current.
ac, exhaust
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Wow, more exhaust woes. Hans Misc. Chit-Chat 14 May 27th, 2005 02:08 PM
NRP COMPLETE Exhaust for '97 OBDII D90 dmarchand For Sale - Parts 9 September 30th, 2004 09:07 AM
The sweet smell of exhaust!! bd90 Defender Technical Discussions 2 February 1st, 2004 07:46 AM
