Bench Bleeding Master Cylinder - Defender Source
Old October 16th, 2015, 07:41 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Looking for some help on bench bleeding a new master cylinder. On a very old truck it came with a bleeding kit but this one doesnt. Any help would be greatly appreciated.
Nick
Old October 19th, 2015, 05:30 PM
Greg S
Greg Sutfin
1986 90
Fill it with fluid, stroke the piston so fluid totally fills the bore right to the outlet. Make sure there is no bubbles of air left in there anywhere. Done.
Old October 19th, 2015, 06:22 PM
Careful you don't get sprayed with brake fluid from the hole.
Old October 19th, 2015, 09:35 PM
97-D90-736
Nick Vogel
Ended up shoving some hose in the ports and pointing them into the cylinder. From there, I got it bleed and dropped it in.
bench, bleed, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Brake Master Cylinder Rebuild HELP Heath Defender Technical Discussions 2 August 7th, 2006 05:11 PM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
