belt tensioner question - Defender Source
Old September 18th, 2011, 05:25 PM
spartan's Avatar
spartan
Fred
83 D110
95 D90 with 103,000miles. While replacing the belts I noticed both belt tensioner bearings were a little noisy. Nothing I noticed while driving or listening to the engine with the hood open. I noticed this when removed both pieces and spun the pulley next to my ear.
Should I replace these? Are these prone to go bad?
Old September 18th, 2011, 06:46 PM
they certainly can if they were over-tightened previously.
Old September 18th, 2011, 07:22 PM
they are expensive if you buy the entire unit from AB RN etc. I was able to get the bearing from RDS it was cheap and helped quieten mine down. The belt tensioner is different from the AC tensioner, it may only be the orientation of the pulley.
Old September 18th, 2011, 09:00 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
You can get the bearing from your local NAPA, part # 6203-2RSJ, costs about $12
300TDI Timing Belt Tensioner Viton For Sale - Parts 1 September 2nd, 2011 10:31 AM
300TDI serpentine belt tensioner bearing R&R Viton Defender Technical Discussions 3 August 31st, 2011 09:15 PM
Freelander Timing belt Tensioner mjekogian For Sale - Parts 0 August 11th, 2010 12:44 PM
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
