belt squeel - Defender Source
Old March 8th, 2005, 10:42 AM
belt squeel
at start up the belts, not sure which one sqeels for a second or two, should I try some "belt dressing" or tighten it via the alternator??
Old March 8th, 2005, 10:50 AM
Tighten them or replace them. belt dressing just covers a problem it doesn't fix it. Does it squeal worse when the heat and headlights are on? Or when the AC is switched on? Check for play all the belts can be tightened easily enough.
Old March 8th, 2005, 11:52 AM
nah just at start up, I never use the AC, they never make noise when the heat lights (electrical) stuff is running. when I have been driven it and has had time to warm up a lot it doesnt do it, mostly does when it is cold and just at start-up.
Old March 8th, 2005, 11:39 PM
dameek
Dennis Meek
95 D90 #2826 Bought New
Chances are its your power steering belt. I just replaced all my belts and I had to re-tighten the power steering belt as on start-up it squealed.
Old March 9th, 2005, 02:13 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Also, I take a bar of soap and hold it VERY CAREFULLY against the inside of the belt while the engine is running to remove any grease/oil on squeaky belts. Loose belts are easy to identify.
Old March 9th, 2005, 05:43 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
change your belt s.i had the same problem with my disco on cold mornings it used to scream till belts got warm,changing them fixed it
Old March 9th, 2005, 08:20 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I heard the soap thing works well
Old March 9th, 2005, 08:21 AM
yeah I have heard that also, I checked the power steering fluid it needed a "top up" I am not sure that this contributes to the problem but o well. thanks for the input I might change the belts sometime.
Old March 10th, 2005, 03:09 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
topping up changes nothing with the squeel, but still good to do. Try the soap--l use Neutrogena and it works fantastic (no oily residue...._)
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
1995 Bestop Soft Top (Belt rail) - FOR SALE jam90 For Sale - Parts 7 January 11th, 2006 10:50 AM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
