Belt removal on a 94 - Defender Source
Old September 15th, 2011, 09:25 AM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Does anyone have trick for removing belts?I've got the radiator out for repairs so thought I might as well replace the belts.
All the tensioners and loosening bolts are loose. The water pump belt came off pretty easy. I had to cut the alt belt off, and the PS belt won't budge. Any suggestions?
Old September 15th, 2011, 10:21 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Did you loosen the alternator tensioner? It has those 2 nuts you loosen with a sliding mechanism. Should have come off real easy.
http://www.fwd.com.au/media/catalog/...eRover1vha.jpg
Old September 15th, 2011, 10:40 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
On the power steering pump, there's two pivot nuts to loosen, and also the adjuster bolt on the bottom. But there's not always enough range to the adjustment, so you may not be able to get the belt over the pulley. Best bet is to just take the pulleys off... and then go up one size in the belt lenght.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 15th, 2011, 11:31 AM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Did this, still didn't have enough tension to remove belt so I cut it off. Hopefully not as hard to replace.
------ Follow up post added September 15th, 2011 10:33 AM ------
-Hans
Might have to do this,thanks.
Old September 15th, 2011, 11:43 AM
Take a picture of your alternator tensioner loosened up...I'd be surprised.
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
94 Best Top - Belt Rail mgrgpg For Sale - Parts 3 September 29th, 2005 03:02 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
