belt removal - Defender Source
Old January 13th, 2014, 06:21 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
belt removal
Anyone have a link to a good write-up for removing and replacing both the fan belt and alternator belt on a NAS 3.9 1994 D90? Does the fan and shroud have to be removed?
Old January 13th, 2014, 06:29 PM
it helps to remove the shroud as well as the fan, I generally have found it easiest to loosen the fan from the water pump and pull it out with the shroud. I am not sure when Rover changed the belt configuration on the Rovers but its a breeze. Napa has a variety of belts at different price points.
Old January 13th, 2014, 06:35 PM
CaptMidnite
Daniel Choi
I see the alternator belt is a matter of just unbolting and adjusting the tensioner.
As for the fan belt, do I loosen/unbolt the idler pulley?
Old January 13th, 2014, 07:04 PM
Just remember...it's passenger side to driver side to loosen the viscous fan clutch (i.e. clockwise if you're standing in front of the vehicle facing it). Ask me how I know: http://www.defendersource.com/forum/...ad.php?t=40545
But technically I don't *think* you need to remove the fan to do the belts, though it may make it easier. I replaced all of my belts at a later date, and just can't recall if I pulled the fan at that time (pretty sure I did not). The power steering belt was more of a bitch, and I actually ended up just pulling the bolts that hold the pulley on and slipping the entire pulley off to replace the belt (which is actually how many shops do it).
Just remember after some time on there you'll need to re-tension the belts after the seat/stretch.
------ Follow up post added January 13th, 2014 07:10 PM ------
Yes, as you lay underneath the truck you can look up at the idler pulley and you'll see the adjustment bolt on there, just loosen it and you'll be able to rotate the pulley enough to loosen & get the belt off.
Old January 13th, 2014, 07:44 PM
go here http://lhsw.com/d90/
download lhp28
Its 148meg but it will answer any question you might have about wiring diagrams, workshop procedures, or part numbers. It even has the original owners manual and service bulletins. Its basically everything Rover ever published about the NAS spec trucks.
Old January 13th, 2014, 08:58 PM
CaptMidnite
Daniel Choi
Thanks everyone, very helpful!
Belt removal on a 94 Lindy Defender Technical Discussions 4 September 15th, 2011 11:43 AM
Belt removal on a 97 thelandroverguy Defender Technical Discussions 10 July 31st, 2011 09:41 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
