Belt and Hose Kit - Defender Source
Old January 8th, 2009, 12:23 PM
JRW's Avatar
JRW
94 D90 ST #1247
Belt and Hose Kit
I have both the belt and hose kits in transit from AB for my 94 3.9 ST. At the same time I am going to replace the thermostat and the heater blower motor.
Anybody have any sage advice, comments, thoughts or cautions to share before I get started? Would there be any benefit to the board to document the process for a tech article?
Thanks in advance.
Old January 8th, 2009, 04:19 PM
"Would there be any benefit to the board to document the process for a tech article?"
Yes. I am sure many would appreciate it.
Old January 8th, 2009, 04:42 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I too think a tech article would be very cool.
Sorry that I dont have much to add as far as advice goes.
Old January 8th, 2009, 06:04 PM
Grover's Avatar
Grover
Thumbs up
Thanks in advance.
There is no drain cock on a stock radiator. Use a siphon pump to pump out as much coolant from the radiator as possible, then pull the bottom hose to completely drain.
The heater hose coming from the upper intake to the heater pipe above the PS valve cover can be a real PITA to remove due to the valley seal braket lip. Be prepared to cut the hose off. With a file, I filed the lip down about a 1/16" on the valley seal braket where the hose passes over for ease of installation for the new hose.
Good luck!
Cheers...
Old January 8th, 2009, 06:10 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
If you want to do a full flush there are also two drain plugs on the engine block, on a D2 they stick one inside the right engine mount, not sure about on a V8 Defender, a whole lot more comes out when you pull them.
Old January 8th, 2009, 06:46 PM
Montgo1715
D Montgomery
1994 AA
John, If you want a hand, or at least someone to hand you beers, let me know. Dakon
Oh, I've got the repair manuals on CD, not sure if it will help or not, but you're welcome to it.
Now that is a big trunk. It holds a tuba, a suitcase, a dead dog, and a garment bag almost perfectly.
kit
4.6 conversion experiences nikojo Defender Technical Discussions 35 June 25th, 2017 10:45 AM
Many AC Systems for Sale, new and used V8 and 300 DI SafariHP The Vendors Loft 9 June 16th, 2015 07:16 AM
quick help on heater hose routing! kevincdoyle Defender Technical Discussions 16 February 21st, 2007 05:35 PM
Oil cooler hoses rvrsrvc For Sale - Parts 116 October 16th, 2005 05:47 PM
another one bites the dust--110 evilfij Misc. Chit-Chat 48 March 31st, 2004 01:58 PM
