Bell housing question - Defender Source
Old July 2nd, 2014, 12:20 PM
MikeG
MIke Gordon
1994 Defender 90 NAS
Can anyone tell me if the bell housing from a series Rover will fit between a 300tdi and an R380 trans? From, what I've been able to find, there is some compatibility between the 200 td and the LT77 but I can't find much info on the R380.
Old July 2nd, 2014, 01:38 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If you are asking if you can remove a bellhousing from a series transmission and bolt it up to an R380, the answer is NO.
While the LT77 belhousing is similar, it is a different length front to back, so you cannot use it on an R380 because the R380 first motion shaft (primary pinion) is of different length.
RDavisinVA
Old July 2nd, 2014, 01:43 PM
What exactly are you trying to do?
Old July 2nd, 2014, 01:45 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Mike,
I have a R380/300TDi bellhousing you can have if you can pick it up. When we replaced the clutch we found that one of the studs and surrounding area was missing. It was running around like that for many years, so I'm not sure how imperative it is......um wait, before everyone laughs at me and jumps all over me for suggesting to install a chipped bellhousing....consider the fact that an OEM bellhousing can run as high as $4-$500 (and I think much higher depending) depending upon where you find one.
I was thinking that depending upon what your needs are (fitting purposes, mock-up, or temporary), my bellhousing may fill the void and its free.....and relatively local.
I'll take pics later.
Old July 2nd, 2014, 01:49 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Originally Posted by Jackie Treehorn View Post
Mike,
I have a R380/300TDi bellhousing you can have if you can pick it up. When we replaced the clutch we found that one of the studs and surrounding area was missing. It was running around like that for many years, so I'm not sure how imperative it is......um wait, before everyone laughs at me and jumps all over me for suggesting to install a chipped bellhousing....consider the fact that an OEM bellhousing can run as high as $4-$500 depending upon where you find one.
If Mike doesn't take this, I am interested and would pay for shipping.
Old July 2nd, 2014, 02:21 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Mike,
You could most likely have the belhousing repaired,
It's cast aluminum and can be welded.
RDavisinVA
R380 Bell Housing Question d110pickup Defender Technical Discussions 4 November 18th, 2012 09:21 AM
300 tdi short bell housing pendy For Sale - Parts 1 April 27th, 2010 04:05 PM
300 tdi short bell housing pendy For Sale - Parts 9 February 6th, 2009 11:22 AM
300 TDI R380 Shifter / Bell Housing SafariHP The Vendors Loft 0 October 1st, 2008 07:24 AM
WTB: Bell Housing for R380 NashvilleRover Wanted 9 August 17th, 2008 07:32 PM
