being lazy - Page 2 - Defender Source
Old April 27th, 2008, 11:15 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
No. Not as of yet anyway. Nothing abnormal in any way/aspect.
This is where I'm supposed to write something witty and funny; or something.
Old April 28th, 2008, 08:26 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by JBOD77
Increase pick-up, decreased engine braking, throaty sound. I love it. The only real issue I could see would be the sound, I know some of you don't prefer the loud, in-your-face, Borla exhaust and this only heightens the noise.[/font]
Hey Jonathan,
Just for my own edification, can you explain how the air filter install would decrease your engine braking? I was always under the impression that engine braking was a function of cylinder compression (hence the reason Diesels kill gas engines with engine braking), and as such, you would have to decrease cylinder compression to have such an effect, no?
~Scott T.
'95 D-90 ST - AA Yellow
Old April 29th, 2008, 09:51 AM
JBOD77
Jonathan
Not really sure. Perhaps I'm using the wrong expression. I own several Macks and several peterbilts and you're correct with the engine brake on it decreases cylinder compression to slow the truck down w/o brakes or down shifting. What I'm talking about goes as follows. Before the K&N if I were running 70MPH on the highway, downhill and downwind of course, and I were to let up on the throttle the Defender drops to 50-40 quick quickly. Now when I'm running the highway way if I let off the gas it still slows down of course but much much slower than it used to. Engine braking IS the correct term but I understand what you mean b/c it shouldn't effect it. The filter was the only mod performed at that time and it really did make a noticable difference.
Clear "side lights" jaygoss Defender Technical Discussions 12 December 16th, 2009 09:51 AM
Raffle for Hippert's 94 Arles Soft Top - who would be in? JimC Trips, Trails and Events 58 May 19th, 2009 09:10 PM
Air Research M-11 (Garrett) tomaco1 Defender Technical Discussions 10 April 15th, 2009 03:51 PM
Rust! again.... Buckon37s Defender Technical Discussions 9 September 22nd, 2006 11:24 AM
