Before I do something stupid... 300tdi immobalizer/alarm - Defender Source
Old July 3rd, 2015, 12:35 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So in the process of stripping down the 97 300tdi csw ROW, I've come across this tamper proof black box inside the left hand seatbox.
The vehicle did have a security system in it, it had the bonnet sensor, the alarm in the front left wing etc. I never got the fob when purchasing the truck so I have no idea of the functionality of it.
I was assuming this black box was what is referred to as the spider, but I expected there to be a multi connector to unplug it, but the wires just feed in. Unless the connector is inside the tamper proof box.
Ultimately I need to get the wires out of the box so I can feed the through the side of the seatbox to be able to remove the seatbox.
So before I go tampering with this thing I'm hoping to get some feedback about what it actually is and how to proceed.
ID:	124140   Click image for larger version
Old July 3rd, 2015, 12:40 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Oh I also have this that sits in the dash which is part of the alarm as well I believe.
Old July 4th, 2015, 09:50 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So after a bunch of digging in the Euro forums it looks like it is indeed the spider I'm dealing with.
I'm thinking it would be nice to strip this whole alarm system out and replace it with a new engine harness, minus all the alarm junk, ecu etc
Who makes a good 300tdi harness?
Old July 4th, 2015, 09:52 AM
Bobeck and I soldered in a bypass wire in 30 mins. Striping the system requires your get a different main wiring harness.
Old July 4th, 2015, 09:57 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Hmm ok that's a bit more involved. Maybe I should just do the bypass.
Out of curiosity is there someone making the main harness for a 300?
Old July 4th, 2015, 10:01 AM
After doing the bypass I never had further issue and I assure you the truck was used harder than you are likely to. For example driven in water over the bonnet so the alarm unit was fully submerged for extended periods.
Old July 4th, 2015, 10:12 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Good to know, guess I'll stop worrying about it and get back to pulling the engine!
Old July 5th, 2015, 09:45 AM
barjout
Marc Bourget
1996/Tdi DEFENDER 110
I imported my 1996 from Germany and I don't have that black boxe under the left seat. You can get a remote and program it it's real easy. And since we are both from Ottawa I could even show you in person.
Old July 5th, 2015, 11:40 AM
Yup, like Uncle Dougie says, easy peasy. One of my more successful soldering jobs. There is an LR4x4.com thread on how to do it.
Hmmm...
The Definitive Alarm Spider Post - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 5th, 2015, 11:42 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I've pulled apart the box and its out of the seat box now. Once everything is in the new chassis I will have to decide if I want to get the fob and bring it back to life or just do the bypass.
Old July 5th, 2015, 11:55 AM
If you want a 300tdi harness eBay UK is full of them.
Old July 6th, 2015, 09:47 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Thanks for the offer! I may take you up on that when I get to that stage.
Will you be at the All British Car Day in two weeks?
Cheers,
Will
Old July 6th, 2015, 05:15 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Engine harness
As above lots of harnesses on Ebay or you can contact any of the main breakers they should stock them.
If you want a new one try here :Main, Engine & Chassis Harnesses, Autosparks, World leading supplier of classic car wiring looms
regards all
Gren
Old July 6th, 2015, 08:06 PM
barjout
Marc Bourget
Cheers,
Will
I wasn't even aware of that car day. But if the weather is nice I might go with the mini.
Old September 24th, 2015, 11:12 AM
groym
Guylain
1997/110 300TDi
FOB setup
Hi Marc
I have a '97 110 that also came from Germany with only one fob. I was looking to disable the spider with a bypass plug but there is no spider in this unit - it has the DDS at the fuel injection pump.
How did you go about getting a new fob setup for yours?
Merci!
Guylain
300tdi, tdi
Anyone done a 300tdi series conversion before? Sherb Series Technical Discussions 19 March 19th, 2017 07:28 PM
stupid is as stupid does... kevincdoyle Defender Technical Discussions 0 May 11th, 2014 02:21 PM
Stupid Is As Stupid Does Jonesy Misc. Chit-Chat 16 May 21st, 2012 06:54 PM
D90 Alarm System? icurnmedic Defender Technical Discussions 4 May 30th, 2006 12:26 AM
Stupid, Stupid, Question bstraw Defender Technical Discussions 3 February 23rd, 2006 08:48 PM
