Bearing removal on a t-case input gear - Defender Source
Old September 24th, 2009, 03:13 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
What do you use to get these bastards off? there is like no lip to use a puller..
Legend in My Own Mind.
Old September 25th, 2009, 09:17 AM
I would try a chisel made out of 1" x 1/4" mild steel. It shouldn't hurt the hardened surfaces. Maybe a bearing separator if you can get one.
Old September 25th, 2009, 11:21 AM
Pretty sure I used a prybar as that is normally how I get bearings off.
Old September 25th, 2009, 07:17 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
the correct way would be a bearing separator and a press. I'd suppose Daves thought of the mild steel chisel might work. Prybars sound a little rough, but what the hell do I know.....'spose you put them back on with a hammer?
Matt Browne
Old September 25th, 2009, 09:36 PM
Hammer and brass drift.
Note, do not attempt this unless sober.
Old September 26th, 2009, 09:12 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
That is exactly what I did. Came right off. Now I just need a new 26 tooth gear. ANYONE??
Old September 26th, 2009, 10:18 AM
heh heh...the mild steel chisel method is from the Series LR shop manual for removing one of the bearings off the series transfer box output shaft. I only suggested it because I figured there wasn't room for a brass drift.
Randy glad you got the bearings off ok. Are you looking for a cross drilled gear? Ashcrofts?
Old September 26th, 2009, 12:46 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yeah. A cross drilled gear. the one in my spare case is shot
Matt, you going to MAR?
Old September 28th, 2009, 07:06 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
No MAR. for me. Shop is too busy and I've got to stay close to home.
Matt Browne
Input Gear Bearing P/N? LRNAD90 Defender Technical Discussions 3 April 25th, 2009 04:13 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
