battery wiring connectors - Defender Source
Old May 2nd, 2009, 01:47 AM
Ok so i am running a few battery lines into the engine compartment and am wondering what people are using for terminals on the batterys?
Winch - 1 gauge wire
lights - 4 gauge to Pwr distribution block in the engine compartment (able to run 4 lights, 2 headlights + 2 bar lights)
Amp - 4 gauge
D-90 Main Pwr - 1 Gauge (i think)
so that is 2 1-Gauge and 2 4-Gauge wires that need to be hooked up. (and if there are top lights, work lights, etc i want to run another pwr distribution block for those and the relays needed to pwr them)
obviously this is a lot of wiring hanging off the stock connector - looking for ideas here everyone.
Street wires has a terminal which allows 2 4-gauge hook ups easily but the 2 1-Gauge hook ups could be problimatice and it uses an allen bolt to secure the terminal which is a pita from a carry along tool perspective (i.e. i can always use various wrenches but only 1 allen wrench)
95' D90 - daily driver..
Old May 2nd, 2009, 01:50 AM
The one I have for the amp in the lotus I replaced the allen head set screw with a bolt.
YMMV.
Old May 2nd, 2009, 02:09 AM
thanks Ron but the street wires terminal uses an allen head set screw for the terminal connection.
i wanted something that would be simple in the field if needed. ie. a bolt for the battery connection
not sure i can get away from the allen head terminal connection.
there is a distribution block which may work for me. 3 1/0 gauge out 1 in
http://www.crutchfield.com/p_211DBX3...tWires&tp=3001
Old May 2nd, 2009, 02:28 AM
I know, I backed out the set screws and replaced them with small bolts after slathering them with wurth copper anti-sieze (I do this to every bolt I put on). Not sure if it was street wires, but it was similar, phoenix gold maybe, I had it for fifteen years or so but mine did not have a plastic cover and the other end clamps onto the battery, but since it is 2:30am I am not wandering out to the garage to take a picture .
The easy solution is to get a battery with both top and side connections (or marine optima which has three IIRC) and use standard eye connections on the side connections on them to supplement the block.
Old May 2nd, 2009, 09:20 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've always liked these, they come in pos & neg.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
battery, wiring
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
