Battery terminal option - Defender Source
Old June 1st, 2016, 10:15 AM
I saw this in the back of a Maserati and thought it would be a good solution for anyone wanting to have a disconnect and terminals of accessories. I recently redid by battery box and would have used this had I known it existed. I actually spent a good amount of time looking for something similar. The Maserati part number is 233262 and it should be around $40 including a short negative battery cable.
Old June 1st, 2016, 10:34 AM
I have to say, that's pretty handy
Mark Kellgren
KM4BOR
Old June 1st, 2016, 10:44 AM
I would like a terminal like that for the positive side as well, but as far as I know (I may be wrong) positive and negative battery posts are different sizes.
Old June 1st, 2016, 10:45 AM
if that's the real price then its a great deal and it's that price in quid and more in Euro!
Old June 1st, 2016, 10:47 AM
I thought they were the same, but apparently you are correct.
Old June 1st, 2016, 10:51 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Another option to convert most terminals to quick disconnect..
I like these terminals myself..
~Scott T.
'95 D-90 ST - AA Yellow
Old June 1st, 2016, 10:57 AM
The quick disconnects that Carl offered were need and I have some of those. The thing I like about these Maserati connects are the accessory points.
Mark Kellgren
KM4BOR
Old June 1st, 2016, 11:12 AM
Originally Posted by LRNAD90;743714[URL="https://www.waytekwire.com/item/36114/Lead-Battery-Terminal-Military/"
I like these terminals myself..[/URL]
That's what I used, but they don't look very nice.
I really like the ones Carl sells, but I needed to be able to install the main power and ground cables, winch cables, and auxiliary fuse box cables.
Old June 1st, 2016, 11:15 AM
Snowpeak make some that might be more car camping grade ...
Old June 1st, 2016, 11:29 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Maybe I am missing something, seems like a function over form kind of piece to me...
~Scott T.
Old June 1st, 2016, 11:40 AM
not tacticool or overland chic enough for carbon fiber infused titanium car campers!
Old June 1st, 2016, 11:44 AM
Both would function fine, but the Maserati terminal would be a cleaner setup. I'm not going to go back and change mine, but had I seen these before buying the mil spec ones, I would have bought them. I just ordered one for a friend through the parts department here and my cost was $27.28
Old June 1st, 2016, 11:53 AM
Cheers bro! Although i normally like to google the price of my gifts after i get them rather than know up front ... ;-)
Old June 1st, 2016, 11:56 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Is it the multiple accessory posts peopel are getting excited about? Personally I don't like to hang a lot off the Battery Terminal itself, prefer a large gauge connection (through a breaker) to another separate fuse block that feeds accessory lighting, electronics, compressors, etc..
So pretty much the Starter/Charge cable, Winch Cable and Cable feeding accessory block. Its even a good idea to do a fuse block (or at least a terminal block) for the ground connections to run back to for electronics, etc (again with a single large gauge cable from the negative terminal)..
~Scott T.
Old June 1st, 2016, 11:58 AM
That's what is perfect about this terminal, one stud for the main vehicle cable, one stud for the fuse box, and one stud for the winch.
Old June 2nd, 2016, 12:26 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Love it! Solves a great many problems. Thanks for the info.
So will this qualify my D as a Land Rover Maserati hybrid? ;-) Sounds killer!
Old June 2nd, 2016, 07:15 AM
Naplm00
Matthew
Amazon sells something similar, look for car audio battery terminal
Old June 2nd, 2016, 07:52 AM
Got a link? I couldn't find any.
Old June 2nd, 2016, 07:57 AM
Naplm00
Matthew
https://www.amazon.com/gp/product/B0...0QPR9PNTQE0K0C
An example, I searched for "car audio battery terminal" lots of options varying wildly in quality so ymmv
Old June 2nd, 2016, 09:01 AM
Another option
Slee aluminum battery extensions..
Couldn't find the separate ski for them but they are reasonable - no quick disconnect though, which makes the Maserati ones pretty slick.
http://www.sleeoffroad.com/products/...ts_battery.htm
95' D90 - daily driver..
battery
Battery relay for dual battery install plus cables jonathon For Sale - Parts 1 February 3rd, 2014 07:36 AM
LR3 battery terminal clamps Grover Misc. Chit-Chat 7 January 22nd, 2014 07:07 AM
best "drop in" option for ROW battery tray? alastair Defender Technical Discussions 5 September 11th, 2010 02:44 AM
Optima Battery Aux terminal Screws sflash868 Defender Technical Discussions 1 June 5th, 2009 01:33 PM
Battery Option mdmccallum Defender Technical Discussions 0 July 9th, 2008 11:24 PM
