Battery recomendation - Page 7 - Defender Source
Old December 28th, 2015, 04:48 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
What is the battery conditioner of choice these days... and why? Any feedback on KeyLine?
ID:	138074   Click image for larger version
Old December 28th, 2015, 04:56 PM
I use the Ctek 3300s...have probably a 1/2 dozen of them:
http://www.amazon.com/gp/product/B00...rch_detailpage
It's essentially what the Ferrari/Lambo guys use, and figure if they are good enough for their rides they are good enough for my sh*tboxes .
Old December 28th, 2015, 04:57 PM
I use a Noco Gen1. 10 Amp, waterproof. They do a smaller version that is good for most people the Genm1, 4 Amp.
Old December 28th, 2015, 05:40 PM
Use Sears units. If your truck lives outdoors, make sure you plug it into a gfi protected outlet
Old December 29th, 2015, 01:51 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
I ended up staying with the Gel and picked up the DieHard Advanced Gold AGM Battery (Group Size 34). We will see how it stands up - Time will tell
Good call re: the trickle charger / maintainer. Are those ever set up so you can plug them right into the cigarette lighter? just thinking that would be very easy.
The reason I ask, because I picked up a Marine Solar Trickle Charger for my Dad's 13 Whaler and it simply plugs into the cigarette lighter. It keeps the batt charged for when the boat isn't in use, but the bilge pump is running, etc. Overall the set up works really well.
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old December 29th, 2015, 06:33 PM
Frank84
Frank Battersby
95 D90
Yes, but it only works when the cigarette lighter is energized so if you need to leave the key in the on position that may be less than ideal.
'95 Soft Top
'89 Classic Tdi
Old December 29th, 2015, 07:57 PM
That depends on the vehicle. I don't know about how they are on Defenders, but a lot of vehicles have aux outlets that have constant power.
Old December 29th, 2015, 08:37 PM
ive used the ctek charger, it does a good job on the agm batteries
Old December 29th, 2015, 08:46 PM
KKilo23's Avatar
KKilo23
Kenny
Same
Old December 29th, 2015, 09:25 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Originally Posted by KKilo23 View Post
Same
Which charger are you guys using?
I mean model.
Old December 29th, 2015, 09:26 PM
lightwriter's Avatar
lightwriter
Carlos Ascencio
'84 One Ten
Same here. I brought the agm on my BMW back from completely dead.
Old December 29th, 2015, 09:45 PM
KKilo23's Avatar
KKilo23
Kenny
I mean model.
CTEK 3300 and 7200. Either will work.
Old February 22nd, 2016, 02:00 PM
Rufus's Avatar
Rufus
Rufus
Quick question - I picked up a CTEK 3300 do you guys recommend snowflake mode or car mode for a DieHard Advanced Gold AGM Group Size 34? I would appreciate any help trying to figure out the details. CTEK FAQs say "It depends. Optima and Hawker recommend snowflake mode. If there is no indication on the battery, use car mode for batteries over 14Ah or MC mode for batteries under 14Ah"
Old February 22nd, 2016, 02:25 PM
I just run it on "regular" battery mode, unless you think it's going to be extreme cold temps. I keep my Interstate Marine batteries on a charger in upstate-NY all winter and even with the extreme cold I just use the "regular" setting wit no issues. The Optima may recommend snowflake mode because it's a gel battery?
Old February 22nd, 2016, 02:33 PM
Optima in an AGM, not gel.
Old February 22nd, 2016, 05:50 PM
Rufus's Avatar
Rufus
Rufus
Thanks - yea it says snow flake for AGM batts (mine is an AGM Gel) but then the FAQs says it "depends" so I'm not sure
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
Sealed battery? OCD90 Defender Technical Discussions 4 December 22nd, 2003 01:43 PM
