Battery recomendation - Page 5 - Defender Source
Old April 11th, 2014, 05:25 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Originally Posted by chris snell View Post
The DieHard Platinums are not what they used to be. Get an Odyssey.
You've posted this before, but never said why.
------ Follow up post added April 11th, 2014 05:33 AM ------
Originally Posted by javelinadave View Post
Reviving an old thread.
Is there any reason to NOT get a Diehard Marine Battery and get a conventional battery instead? I like the spare posts for tying in a separate fuse panel for accessories.
If you don't need a marine battery a starting battery that has both top and side posts will work. Use one set of posts for starting and the other for the auxiliary connections. If that's your only concern.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 11th, 2014, 06:10 AM
I've long since given up trying to decide which battery is better than another. Also decided that replacing a battery as it's warranty expires is far better than being stranded on the side of a road for the sake of $130-150.
Breakdowns suck, preventable breakdowns hurt cos you'll be kicking yourself when it happens.
Old April 11th, 2014, 02:28 PM
I went with the Diehard P2, it was on sale. $249 out the door.
Old April 11th, 2014, 02:51 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Give the 9A34m Deka Intimidator AGM Deep Cycle Marine/RV battery a look. I can get over 1100 CCA out of mine during the summer temps. Thinking Jonesy is using the same with good results.
http://www.dekabatteries.com/default.aspx?pageid=1804
Old April 11th, 2014, 03:00 PM
Originally Posted by down_shift View Post
Give the 9A34m Deka Intimidator Deep Cycle Marine/RV battery a look. I can get over 1100 CCA out of mine during the summer temps. Thinking Jonesy is using the same with good results.
They are the Land Rover of batteries and not because they leak and smell bad.
I looked at Deka batteries online. My issue is that the closest dealer is a 45 minute drive across town. I live in the 5th largest metro area and there is only one dealer. If their service sucks, I'm screwed if I have an issue.
Old April 11th, 2014, 03:03 PM
But you'll only have to visit them every 5 years or so.
down_shift's Avatar
down_shift
Russell
Uh, that is a good thing, right?
------ Follow up post added April 11th, 2014 03:03 PM ------
Dave, read the spec sheet and reviews. You will be happy w/ the choice.
Old April 11th, 2014, 03:28 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
1 dealer within 50 miles of downtown Chicago.
Old April 11th, 2014, 03:33 PM
Diehard Platinum
Old April 12th, 2014, 07:56 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Friday I called the person at EnerSys I've talked to a couple of times before (the first time in '09 when someone was claiming the Platinums were an Odyssey lower quality store brand) and she told me that the Platinums are still identical to the Odyssey and made on the same production line, just as they have been since they started making them in 2007.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 6th, 2015, 11:43 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Do you guys still like the DieHard Platinum after running it for a little while?
Mine doesn't hold a charge anymore and it is almost exactly 5yrs old. I have read that it doesn't do as well in cold temps, and I feel like I have experienced that having to jump it off the tractor. Maybe my expectations were too high.
I need to find a replacement batt and Im wondering if the platinum is worth it.
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old February 6th, 2015, 11:50 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Loved mine - but yeah, it died literally at 5 years.
-Ren Ching
Old February 7th, 2015, 12:02 AM
Batteries in Phoenix last 2-3 years due to the heat. I would love a battery to last more than that. As for battery of choice, I run Sears Diehard Platinum's too.
Old February 7th, 2015, 12:24 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Upon your recommendation, I'm now running a Diehard Platinum 850CCA.
It replaced a still working but tired Wal-Mart battery, so you're welcome to that battery if you need something to get you through.
I just replaced the Cayenne battery last month as well (also a giant 800CCA) because it was 5 years old and when it sat dormant for more than a few weeks it would become weak. I think the brand was Varta, but I'll have to check.
I haven't heard of any battery really lasting longer than five years (consistently).
Old February 7th, 2015, 09:22 AM
Rufus's Avatar
Rufus
Rufus
I recommended the platinum for you to help support all your electronic components for your "Rave" Beach parties. All that needs a lot of energy man. Why else do you think you are known as "Jackie Treehorn"?
Old February 7th, 2015, 09:27 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Optima D31A. Do it. 900 CCA and 1125 CA. Only get it if you can get a discount on it, though.
Old February 7th, 2015, 09:57 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Still love my interstates.
Old February 7th, 2015, 10:38 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
just get the best one from autozone. their swap policy is very good, and will refund/apply a credit to a new battery depending on the coverage.
Old February 7th, 2015, 10:44 AM
jafir's Avatar
jafir
Jafir Elkurd
Interstates leak too much, in my experience. I'd be afraid it would rot out my battery box
------ Follow up post added February 7th, 2015 09:47 AM ------
Don't they have 100 month prorated warranties?
Also, are you charging it with an AGM compatible charger? I had an AGM in a Miata (don't laugh) that was 10 years old and still working well.
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
Sealed battery? OCD90 Defender Technical Discussions 4 December 22nd, 2003 01:43 PM
