Battery problem - Defender Source
Old October 6th, 2012, 02:45 PM
Hawkins
Will Hawkins
1997 Defender No Top
Battery problem
Where is the battery on a 1997 d-90
Old October 6th, 2012, 02:50 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Under the driver side seat I believe.
Under the drivers seat. Pull the handle at the front of the seat to remove the seat base. Then remove the black cover. Voila ... Battery.
Old October 6th, 2012, 02:55 PM
Hawkins
Will Hawkins
Thank you very much
Old October 6th, 2012, 04:19 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Actually PULL UP on the front of the seat (note the alignment studs on the back of the seat for proper re-insertion & position). See the metal plate below where the seat was, there's a catch on the front. Un-snap it & slide plate forward.
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Alternator/Battery problem - Repost Eric_S Defender Technical Discussions 1 January 19th, 2004 09:57 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
