Battery light not coming on - Defender Source
Old June 5th, 2014, 07:49 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Just noticed battery light not coming on upon start-up (1994 defender 90 V8). Not sure how long it's been out. Starts fine, and unless it's a new issue, cars been driving fine. Any thoughts?
------ Follow up post added June 5th, 2014 06:55 PM ------
Bulbs fine, all connections to alternator look intact.
Old June 5th, 2014, 08:05 PM
Wiring issue to the bulb?
Bad ground to the bulb socket?
Evil Lucas curse?
Check for power at the light with the ignition on. If no power you need I trace the fault back from there. If there is power it could be an alternator fault or a dead wire between the light and the alternator.
Old June 5th, 2014, 08:06 PM
How it works. 12v goes to the bulb. The circuit grounds through the alternator when it is not producing power or has a faulty diode.
Old June 5th, 2014, 09:12 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
It could just be a bad bulb. Had the same issue with my oil pressure light.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old June 6th, 2014, 04:02 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Bulbs good, will run auxiliary ground to bulb socket this weekend.
Old June 7th, 2014, 03:18 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Drove car last night starts fine. Still no battery light at start-up. Multimeter to battery before starting 13v and running 15.5v. Seems to be charging blue top optima but no battery light, any thoughts.
Old June 7th, 2014, 03:40 PM
Did you do the tests I suggested?
Old June 7th, 2014, 04:10 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Ran auxiliary ground from alternator housing to multimeter common leed and positive leed to bulb socket and there was 12 v in position 2.
Old June 7th, 2014, 04:31 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Which wire runs from battery light to alternator (ground)?
Old June 8th, 2014, 08:10 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
5 hr. Wheeling trip this weekend. Started fine every time, battery light still not on, doesn't seem to matter battery still charging( strange). Not going to dig any further until it becomes a problem. Thanks for the input.
Old July 15th, 2014, 06:01 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Update: 7/15/14
Battery light back on? Must be Lucas gremlins!
------ Follow up post added July 15th, 2014 05:02 PM ------
Battery light back on? Must be Lucas gremlins.
Old November 19th, 2016, 12:25 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Problem ended up being a bad diode in the alternator, which also created a slow battery drain issue when parked. New Magneti and all is well.
Battery relay for dual battery install plus cables jonathon For Sale - Parts 1 February 3rd, 2014 07:36 AM
its coming back (not to me) d90boy The Flea Market 27 February 11th, 2012 08:34 PM
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
battery light.... Campbell Defender Technical Discussions 3 September 2nd, 2005 11:47 PM
battery light Campbell Defender Technical Discussions 1 July 6th, 2005 08:05 AM
