Battery light and cutting off at idle - Defender Source
Old January 22nd, 2010, 12:48 PM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
Guys, whenever I start the engine, my battery light comes on (with my oil light on sometimes). I have to start the engine by pumping the gas pedal, to eventually get it started. Once I get it started, it sometimes stalls out when I back out of the driveway, and I have to restart. Also, sometimes at idle soon after starting the engine, it will cutoff/stall and I'll have to restart at the stoplight. Any suggestions on what's going on? Also, is there a way to get my truck started by just turning the key with no gas pedal pump. It sounds horrible on start up and it's a pain in the ass to restart at stoplights. Thanks guys!
-Ryan
Old January 22nd, 2010, 03:46 PM
You have an EFI problem. Steeper motor maybe. You basically need to go through a step by step fault check. Otherwise you are wasting time.
Old January 22nd, 2010, 04:40 PM
BEIS's Avatar
BEIS
RYAN BEIS
John, thanks. My truck has an edelbrock carb on it though..
-Ryan
Old January 22nd, 2010, 04:47 PM
Shoot it and put it out of its misery then. Those bloody things are the spawn of the devil. I have a friend with one and years of trying to tune it and it still is a crap shoot getting it to start.
Check the idle mixture and turn up the idle speed.
Old January 22nd, 2010, 04:52 PM
BEIS's Avatar
BEIS
RYAN BEIS
Cool man, I'll give her a try. Thanks for the advice though haha
-Ryan
Old January 22nd, 2010, 04:54 PM
I thought we were not going to help Ryan until he posts pictures of his truck.
Old January 22nd, 2010, 05:13 PM
Have you tried going off road yet?
The one on my friend's won't run past a 15 degree angle.
Old January 22nd, 2010, 05:36 PM
Yes no help till he posts pictures!
Do you still have your choke? I have to make judicious use of it to start my 110 (original ?solex? carbs)
battery, ht, idle
LED's installs - Lets see 'em JimC Defender Technical Discussions 73 August 30th, 2012 12:05 AM
Engine cutting out problem headdamage Defender Technical Discussions 3 August 15th, 2007 11:52 PM
Relocating bumper turn signals to the upper light housing paulb Smaller Projects 1 March 17th, 2007 10:50 AM
Problem with Engine cutting out waveridin1959 Defender Technical Discussions 7 March 3rd, 2004 06:01 AM
