Battery light - Defender Source
Old December 6th, 2010, 12:14 PM
willr's Avatar
willr
WILL RAGSDALE
NONE
Battery light
I have a 985 110, 300tdi and I replaced my battery with a Optima red top battery and now my battery light is on. I am not having any issues starting the truck but the battery light stays on. Has anyone had this problem?
Old December 6th, 2010, 12:30 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
If this is just after a battery change, check your connections.
- Charles Eames
Old December 6th, 2010, 12:32 PM
maleger
Marc-Andre Leger
I had this problem once.... until the truck died after the battery was discharged completely and I stalled (it took about 5 kms or 3 miles). It was a defective alternator, which I replaced. The pulley had beed mis-installed by a mechanic and was slipping, thus not charging and stripping the shaft. I replaced the alternator and got the old one rebuilt (new shaft).
battery, ht
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
Battery light comes on arbik Defender Technical Discussions 5 December 16th, 2005 02:38 AM
battery light.... Campbell Defender Technical Discussions 3 September 2nd, 2005 11:47 PM
battery light Campbell Defender Technical Discussions 1 July 6th, 2005 08:05 AM
