battery/ electrical issues - Defender Source
Old April 23rd, 2004, 03:52 PM
steve_brooks's Avatar
steve_brooks
Steven Brooks
'94 D-90 #1281
I have a '94 D-90 which is a third car and so it sits for extended periods. I have several auxiliary electrical options including a winch and Hella lights. I have engine starting trouble requiring frequent jumps. I am on my second yellow spiral cell battery (which is 2 yrs old) and I replaced the alternator 4 years ago. The car won't start again despite a jump and then driving for 30 minutes. If it is the alternator, is there a better alternator to install. If it is the battery, is there a better alternative than the yellow Optima spiral cell? I would appreciate any feedback. You can post to this thread here, or email me at zekeyb@comcast.net
Steve
Old April 23rd, 2004, 04:05 PM
Steve, easiest solution by far is to take it to the autoparts store and have them run a test on the battery and charging system. If it is the battery again, I would suggest getting a battery cutoff switch so when you leave it off for long periods the battery does not get drained. You could also buy a solar panel or a trickle charger to keep the battery toped up.
battery, electrical
battery issues dbj836 Defender Technical Discussions 2 June 2nd, 2009 11:23 AM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Electrical - battery killers? Emerson00 Defender Technical Discussions 7 July 3rd, 2007 01:59 AM
Electrical relay issues???? PMHAH Defender Technical Discussions 1 November 20th, 2003 02:32 PM
