Battery Drain - Defender Source
Old April 8th, 2004, 10:57 PM
christsonton
Chris Tsonton
95 D-90
Battery Drain
I just bought a 95 D-90. The battery has drained two nights in a row. I have made sure all dome lights are off and radio is off. I cannot find the power drain. Any ideas would be welcomed. Thanks alot.
Old April 8th, 2004, 11:15 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Chris - This is off subject, but I'm probably 10 min from you in Bath. I go to Hinckley Reservation a lot with the dogs. If you want to get together some time, e-mail me.
Phil
Old April 8th, 2004, 11:29 PM
Marc Weinstein
Marc Weinstein
defender 90 '94
old battery or alternator on the way out if you can't find battery drain
Old April 9th, 2004, 12:04 PM
Pull the pos of the battery one night and then reconnect it when you go to start it in the AM. this will tell you if the battery is bad. Actually the easiest thing would be to take it to an auto-parts store that has a tester, they normally take the tester out to your car and check the batt, alt, and diodes all for free.
Old April 12th, 2004, 10:28 PM
christsonton
Chris Tsonton
95 D-90
Thanks for all the tips. Took it to dealer and they found that one of the battery cables was loose at the car end and was the cause of the draw.
battery, drain
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
D90 battery drain? sharknet Defender Technical Discussions 12 June 22nd, 2004 12:41 AM
Sealed battery? OCD90 Defender Technical Discussions 4 December 22nd, 2003 01:43 PM
