Battery Cutoff Switch ( for the winch ) - Defender Source
Old December 14th, 2015, 03:17 PM
Rugbier's Avatar
Rugbier
Gustavo
Any recommendations ( without spending 200.00 )
Looking to isolate the winch when not in use
I would like to put a Master switch cutoff in the Battery box ( so surface mount )
I know my winch draws 280 at momentary and 487 continuos, I googled but only came up with a Blue Sea rated for 500 continuous at 214.00
NO SIGNATURE
Old December 14th, 2015, 03:22 PM
the rover shop
shayne young
Looking for electric or manual..??
Old December 14th, 2015, 03:42 PM
I got one off ebay. how does $10 sound for 500 momentary and 350 continuous?
try item # 231204454949. seller is perfplusconnection
Mark Kellgren
KM4BOR
Old December 14th, 2015, 03:49 PM
The Dro
Dro
1988 Ninety
500A continuous seems high... Is that a 12,000 lbs winch?
Old December 14th, 2015, 04:08 PM
here is one by Hella rated at 1000 amps for $20
Hella 002843011 Hella Battery Disconnect Switch - Battery Switches
Mark Kellgren
KM4BOR
Old December 14th, 2015, 04:09 PM
the rover shop
shayne young
Yeah... Who's fat arse are you pulling out anyway... Should you happen to need that much amperage you can just take the two cables and put them on the same post....but really unusual to be needing that much amperage for extended pulls...winch gets too hot anyway..
Old December 14th, 2015, 04:12 PM
Even cheaper...
Hella Marine Key Battery Master Switch 2843 - Star Marine Depot
Old December 14th, 2015, 04:23 PM
Originally Posted by Jymmiejamz View Post
nice! I think that's the same one that is oem in nas 110's.
Mark Kellgren
KM4BOR
Old December 14th, 2015, 04:26 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Evan cheaper, disconnect the +cable from the battery when not in use.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old December 14th, 2015, 04:27 PM
the rover shop
shayne young
Even cheaper...don't go wheeling with friends who don't have a winch...you won't need one..
Old December 14th, 2015, 04:31 PM
You cheap bastard!
Mark Kellgren
KM4BOR
Old December 14th, 2015, 04:43 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
I have used these on the winch power lines either under the hood close to the winch or in the battery box
Battery Disconnects - 8-Gauge Quick-Connect Wire Harness for Antigravity Batteries
BUY SOME SHIRTS ---> OverthROW
BUY SOME HATS --->
Old December 14th, 2015, 04:45 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Bourses products. On Amazon
Old December 14th, 2015, 04:50 PM
these don't help with anti-tamper, which was my concern. Google "winch vandalism"
Mark Kellgren
KM4BOR
Old December 14th, 2015, 05:23 PM
Rugbier's Avatar
Rugbier
Gustavo
None of the ones are the type I want for surface
this is
http://www.amazon.com/Marinco-Power-.../dp/B00NW4V64K
However this one goes only to 400 continuous
Yeah yea yeah... I am cleaning the battery box area, with a Blue sea fuse box, and the Battery post have one of of this , so the connect / disconnect cheap ass suggestions will not work
Amazon.com: Kicker BT4 Positive/Negative Competition Battery Terminal with 1/0-8 Gauge and 4-8 Gauge Output: MP3 Players & Accessories
ID:	137099   Click image for larger version
NO SIGNATURE
Old December 14th, 2015, 05:26 PM
Rugbier's Avatar
Rugbier
Gustavo
Correct, aside from the hassle of laying in the mud to connect :-)
Had the Warn Version of that one on the 90, hate it
NO SIGNATURE
Old December 14th, 2015, 05:27 PM
Momentary should be much higher than continuous. Please check the numbers they are likely reversed.
Old December 14th, 2015, 05:30 PM
Rugbier's Avatar
Rugbier
Gustavo
Found a Marinco 720 RV
Has 600amp of continuous
------ Follow up post added December 14th, 2015 05:33 PM ------
Sure about that ?
I thought momentary is pulsing the winch, continuous is when you run the lead full power
https://www.warn.com/truck/winches/src/XD9000i.shtml
NO SIGNATURE
Old December 14th, 2015, 05:57 PM
the rover shop
shayne young
Rockys right... Momentary is higher as it is only for a very short time... Not enough time to really stress or get the contacts hot enough before cooling off...
Old December 14th, 2015, 06:06 PM
Rugbier's Avatar
Rugbier
Gustavo
GOT IT,
That is why I ask as I can't install a light bulb for the life of me
Anyhow, the Marinco 720RV has this
DC Voltage 48
Stud Size (Imperial) 2 x 1/2 in
Stud Size (Metric) 2 x 12mm
Continuous Rating 600
Intermittent Rating 800
Cranking Rating 2500
And the specs for the WARN 10,000
12V DC PERFORMANCE SPECS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 25.9 (7.8) 66 amps 1/10000 (4536)
2000 (910) 13.0 (3.9) 160 amps 2/8000 (3629)
4000 (1810) 9.6 (2.9) 247 amps 3/7280 (3302)
6000 (2720) 7.1 (2.1) 332 amps 4/6670 (3026)
8000 (3630) 5.0 (1.5) 417 amps 5/6230 (2826)
10000(4536) 2.3 (0.7) 502 amps
So it should work right?
NO SIGNATURE
battery, switch, winch
battery cutoff switch ditskovich Defender Technical Discussions 3 August 4th, 2011 03:58 PM
Simple Battery Cutoff? isleofbones Defender Technical Discussions 8 January 3rd, 2011 11:29 AM
FS Hella Battery Cutoff Switch Stmpede For Sale - Parts 27 December 2nd, 2009 11:23 PM
Battery cutoff switch Buckon37s Defender Technical Discussions 1 August 26th, 2007 05:11 PM
Winch Cutoff Switch javelinadave Defender Technical Discussions 24 January 9th, 2005 02:21 PM
