Battery CutOff Switch - Defender Source
Old December 16th, 2015, 09:12 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Has anyone here had any experience with the heavy duty battery cutoff switch from harbor freight. I envision using this during deployments and trips in order to save my battery.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old December 16th, 2015, 09:21 PM
there's a few things I don't trust China on. high tensile strength, brakes and high amperage. the fact that you can get Hella or other marine quality for under $20 makes the choice clear.
Mark Kellgren
KM4BOR
Old December 16th, 2015, 09:25 PM
Grover's Avatar
Grover
Dido...don't cheap out on pop tarts, diapers nor battery cut off switches...
Old December 16th, 2015, 09:32 PM
Harbor Freight switch + your truck could very well =
Old December 17th, 2015, 02:19 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I trust standards in Asia very little. I mean when there is an electrical outlet in the shower..... Hmmm
Mexico either. I've seen wiring in my hotel rooms zip tied to plumbing.
Black Rhino Lives Matter
Old December 17th, 2015, 02:42 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
BlueSea #7700 $150 on amazon prime. comes with a switch so I don't need to pull the seat out or punch unnecessary holes for something like the HF unit.
Old December 17th, 2015, 02:46 PM
Nothing wrong with harbor freight switches. It's a switch. The components are prehistoric. The construction could be done with a chisel and file. The physics were established in the renaissance. The worst case, it fails closed - in which case, it doesn't matter. If it fails open, then your truck doesn't work. If it lights on fire, then there is a problem with battery drain and it has nothing to do with the switch.
The real question is why you couldn't just disconnect the positive lead.
Old December 17th, 2015, 02:56 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
This will make life easier... OJOP The Original Quick Release Battery Connector - Sweden. — Tiktaalik
Still need to install mine & work out new power distribution.
Old December 17th, 2015, 02:57 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Or better yet, leave you truck on a Battery Tender.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old December 17th, 2015, 04:29 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
This.
I use this Deltran Battery Tender all the time: http://www.amazon.com/Deltran-Batter...attery++tender
Never have to worry about my truck running low on juice. Batteries don't die so often from lack of use.
Battery Cutoff Switch ( for the winch ) Rugbier Defender Technical Discussions 21 December 14th, 2015 07:45 PM
battery cutoff switch ditskovich Defender Technical Discussions 3 August 4th, 2011 03:58 PM
Simple Battery Cutoff? isleofbones Defender Technical Discussions 8 January 3rd, 2011 11:29 AM
FS Hella Battery Cutoff Switch Stmpede For Sale - Parts 27 December 2nd, 2009 11:23 PM
Battery cutoff switch Buckon37s Defender Technical Discussions 1 August 26th, 2007 05:11 PM
