Battery cut-off switch install - Page 2 - Defender Source
Join the Defender Source Community Today
Old February 6th, 2012, 07:05 PM
So if killing the fuel pump, I've got a battery power lead that runs from the battery direct to the factory fuse box under the passenger seat (that contains fuses for things like the fuel pump).. In theory could one just install a cutoff switch to interrupt this lead, thereby serving the purpose?
I have a very heavy duty marine switch (shown here: that I was planning to use, but would be overkill for just that small 8gauge lead wire I'd think.
SDO Instagram
SDO Facebook
battery, switch
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
battery cutoff switch ditskovich Defender Technical Discussions 4 August 4th, 2011 02:58 PM
Battery Cut Off Switch Grover Defender Technical Discussions 30 March 29th, 2010 07:58 PM
Can anyone explain what happens after the light switch is turned on? solihul Defender Technical Discussions 3 June 30th, 2005 06:28 AM
