Battery connecting block???? - Defender Source
Old January 24th, 2011, 07:52 PM
Rugbier's Avatar
Rugbier
Gustavo
Is there some sort of block that can be mounted on the frame or bulkhead ( or maybe a single block ) that will allow me to extend the Winch cables to reach the battery ( I am trying to avoid the connect / disconnect one )
thanks
NO SIGNATURE
Old January 24th, 2011, 07:56 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
you mean like a bus bar?
try a boat supply yard/chandlery or West Marine (they seem to be everywhere, even inland)
one brand: http://bluesea.com/category/9/35
Old January 24th, 2011, 08:03 PM
Rugbier's Avatar
Rugbier
Gustavo
Tony , not exactly , thanks
I guess a simple way will be , lets say I want to connect the Pos and Neg wires from the winch, to a mounting point that it is not the battery and it is located on the firewall
I can live with both cables side by side or individually
NO SIGNATURE
Old January 24th, 2011, 08:30 PM
16kpsi's Avatar
16kpsi
Tony Lawson
I'm confused what you are looking for. Are you looking for a Land Rover original part? or aftermarket?
Sounds like you are looking for a block(s) to mount the winch wires too (positive and negative - but obviously the two can't be electrically common). Then it sounds like you want to run power from the battery to that block(s)
which is generally done with items like:
http://bluesea.com/category/9/35/pro...e/overview/399 - most compact option. Need two, one for positive, one for negative
or both in one:
http://bluesea.com/category/9/35/productline/186
Mcmaster-Carr also carries "Distribution bars" that are similar http://www.mcmaster.com/#power-distr...n-bars/=aqids8
forgive me if I am completely missing your point in what you are looking for.
or are you looking for the wire itself?
Old January 24th, 2011, 09:04 PM
Gus the cables on the winch now will be undersized to go all the way to the battery. So they need to be changed anyway.
Old January 24th, 2011, 09:42 PM
Rugbier's Avatar
Rugbier
Gustavo
Pardon the sketch but this is what I want to do, to connect those 4 wires
NO SIGNATURE
Old January 24th, 2011, 09:53 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
goose...give me a call in the AM, I can help you out
frank
Old January 24th, 2011, 09:55 PM
Rugbier's Avatar
Rugbier
Gustavo
Frank,
call you tomorrow ... early like 6:00 am my time *LOL*
NO SIGNATURE
Old January 24th, 2011, 09:59 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
What is the recommended size from winch to batt?
Old January 24th, 2011, 10:37 PM
I guess you mean a thru bulkhead fitting?
https://www.vtewarehouse.com/content..._connector.php
https://www.vtewarehouse.com/content...ngle_salon.gif
Old January 24th, 2011, 11:04 PM
Rugbier's Avatar
Rugbier
Gustavo
Originally Posted by o2batsea View Post
Bill I like it, now how about without going through the bulkhead? let say, I want to meet the wire leads on the bulkhead outrigger?
NO SIGNATURE
Old January 25th, 2011, 12:37 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Run 0g cable to the starter hot lead. Connect winch to starter hot lead. Just an idea
Old January 25th, 2011, 05:19 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Goose, I used a racing battery cutoff switch as my bus bar, that way I can kill power to the winch when not in use.
Semper Fi!
Old January 25th, 2011, 06:01 AM
http://bluesea.com/category/9/38/pro...e/overview/400
Use the model 2018 which has one of each size post. Order thru Jamestown Distributors or Defender.
Old January 25th, 2011, 06:16 AM
Why add a weak link to such a vital component? Putting a connection point where it is subject to dirt and water ingress doesn't help anything. It sounds like you are trying to avoid changing the cables to a larger gauge. No matter how you set it up you are going to need 20some feet of heavy cable. Run them straight to the battery. You can put a heavy switch in there for safety purposes. And/or one of the fancy Blue Sea terminal boxes that are popular. But put it in the battery box or the engine bay if must be. Down by the chassis is no place for such a device.
Old January 25th, 2011, 07:47 AM
I agree with Dave on this. The best thing is new cables of 2 gauge or fatter of marine tinned copper. The lugs should also be tinned copper and securely crimped. These ends should be covered with either the heavy wall MIL spec adhesive lined shrink tube or marine grade adhesive lined shrink. They should get terminal lug covers (boots) to prevent the possibility of a short. I like the cables to be secured every 6 inches or so along the runs, which I like the heavy duty nylon ones for. They can be attached with rivnuts.
Genuinedealz.com is my preferred source. I have the tools to make up heavy cables including the proper crimper for the lugs.
Old January 25th, 2011, 07:57 AM
While i am not as extreme as bill, I do have 1/0 welding cable going back to the battery. 2 guage would be too small to go all the way from the winch to under the seatbox. I borrowed a trick from Jim Pendleton and ran the cables inside 7/8" heater hose.
Old January 25th, 2011, 08:28 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
I'm not sure why you don't want to go with the Warn disconnect. A nice advantage is that you can use the Warn jumper cables with the disconnect fitting.
Old January 25th, 2011, 07:34 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
While as pointed out it is the wrong way to do it, you can get screw butt connectors for heavy gauges at any Wesco.
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
Block sealant (was coolant gasses in rad) Davis Defender Technical Discussions 6 April 6th, 2006 01:08 AM
