Battery Configuration - Defender Source
Old November 25th, 2015, 05:31 PM
kp3ma
Kevin
Just purchased '88 Defender 110 w/ 2.5L 19J engine (LHD).
There is only one battery but has cable for auxiliary battery and shut off. There is no ground hook up on the unattached cable (see pic) - assume grounded to the shut off?
There is a winch on front.
See pic of the battery box with the cables. Any thoughts on the proper configuration? Should I add another battery?
Any advice is appreciated.... new and learning.
ID:	135583   Click image for larger version
Old November 25th, 2015, 05:38 PM
What is the extra cable hooked up to? It's not something that came standard.
Old November 25th, 2015, 05:44 PM
kp3ma
Kevin
It is just as you see.... it is not hooked to anything.
Old November 25th, 2015, 07:52 PM
Remove it. Had one of those unconnected loose wires. Intended for trailer wiring. It shorted against the bodywork. Blew fuse. Truck wouldn't start.
Wasn't until months later when adding in trailer wiring that we figured out why it blew.
Old November 25th, 2015, 08:03 PM
Tommieboy
Thomas
2000 Defender 110 TD5
...or add an aux battery if you need it depending on how you intend to use the vehicle.
Old November 25th, 2015, 09:05 PM
kp3ma
Kevin
What is the real need for auxiliary battery? Needed for winch? Don't mind putting another in if better to have
Old November 25th, 2015, 09:13 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I would take that rat's nest out and start completely fresh. You can build new cables easily. Pos goes to your starter and the ground to the transfer case and from there to the frame. Use some good cable and marine-grade terminals and a single quality battery and you'll have a reliable power source for years to come.
http://www.defendersource.com/forum/...dux-26830.html
I've made some updates to my battery system since that first post; they're detailed further down in the thread.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old December 1st, 2015, 07:55 AM
Aux battery can serve multiple purposes. I think one is to have one battery for accessories and another for starting.
Old December 1st, 2015, 08:08 AM
87 D110 (Ruby)
I have an aux battery in the rear LHS box of the 110 - it supplies power to Auxiliary stuff, and the trailer wiring for a charge to a caravan, or Expo Trailer...plus has a charge wire to the Alternator - so it acts in two modes.
As Doug found out (scared his pants off) make sure you tell people working on the truck...he disconnected the main battery - and couldn't figure out why it kept sparking
Old December 1st, 2015, 08:57 AM
I have an aux battery in the rear LHS box of the 110 - it supplies power to Auxiliary stuff, and the trailer wiring for a charge to a caravan, or Expo Trailer...plus has a charge wire to the Alternator - so it acts in two modes. As Doug found out (scared his pants off) make sure you tell people working on the truck...he disconnected the main battery - and couldn't figure out why it kept sparking
Rotflmao.
The mental image that creates is brilliant!
battery
Battery switch outside the battery box suggestions rankar Misc. Chit-Chat 7 December 25th, 2014 03:13 PM
Battery relay for dual battery install plus cables jonathon For Sale - Parts 1 February 3rd, 2014 07:36 AM
110 3 Door Configuration Ideas Jpayne Misc. Chit-Chat 9 May 5th, 2010 08:52 AM
Muffler Configuration 1of40 Defender Technical Discussions 1 February 26th, 2010 11:13 PM
SW Hard Top preferably POE Configuration madcowdungbeetle Wanted 26 September 4th, 2008 01:44 PM
