Battery Compartment Project - Page 2 - Defender Source
Old September 8th, 2011, 08:35 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I don't like terminals that leave the conductors open to the elements or cause the cable to be supported by the conductor.
This how I do all of mine, with red for Pos of course.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 8th, 2011, 02:25 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
Kyle - went with a very similar amp, the JL Audio D-class amp JL XD400/4 (figured if it was going in the compartment a high efficiency low temp class D or class T amp). Main reason I went with the JL is that I had read some feedback that the Alpine got a little warm. JL like Alpine has a pretty solid reputation as well. Would be interested in seeing a picture of the setup if you get a chance to post.
I will get a pic up here soon im working on installing my alternator right now then ill get u a pic..
I wonder if I can drive over that..?
Old September 8th, 2011, 04:22 PM
maleger
Marc-Andre Leger
I put my battery on the rear wheel wells in nautical battery holders. One on each side. I put a nautical A-B switch selector and use the seat battery container for storage.
I made a custom cubby box (plywood + epoxy) in wich I put my subwofer amp and a Poly-Planat radio + a CB and, soon, a HAM radio. I have a master cutoff doe all that in case of wading, but this puts my water line at more than 36 inches. In my opinion the seat / battery box is way to low to be usefull and trying to make it really watertight is nearly impossible.
Old September 8th, 2011, 05:56 PM
Antichrist's Avatar
Antichrist
Tom Rowe
If all you have in the seat box is a battery and you have good connectors it doesn't need to be water tight. Obviously you don't want it holding water (so there's an argument for not making it water tight) but submersing the battery won't hurt anything.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
battery, part
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Battery Compartment Cover bjf Wanted 1 August 1st, 2007 06:20 PM
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Rubber Plug for Battery Compartment jbird Defender Technical Discussions 1 June 6th, 2004 01:12 AM
