Battery compartment Help - Defender Source
Old February 25th, 2016, 08:49 AM
generalcutter's Avatar
generalcutter
Daniel
1988 Defender 110
How do I secure my battery in my 1988 110? Do I need two J bolts and a battery frame or is there a better way??
Old February 25th, 2016, 09:00 AM
i have dual batteries secured by the correct j hooks. never had an issue
Mark Kellgren
KM4BOR
Old February 25th, 2016, 09:35 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Stock should be a 'V' shaped metal bar with two long 'J' hooks that hook into the bottom of the compartment, like this (Random Internet Photo)..
Is that what you are looking for?
~Scott T.
'95 D-90 ST - AA Yellow
Old February 25th, 2016, 09:56 AM
generalcutter
Daniel
1988 Defender 110
Thanks everyone. I found the L bracket and J hooks with wing nuts thru Rovafarm.com and have them ordered. Thanks
battery, part
Battery Compartment Makeover JKC Defender Technical Discussions 6 December 1st, 2011 10:49 AM
Battery Compartment Project silverlight Defender Technical Discussions 23 September 8th, 2011 05:56 PM
Battery Compartment Cover bjf Wanted 1 August 1st, 2007 06:20 PM
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Rubber Plug for Battery Compartment jbird Defender Technical Discussions 1 June 6th, 2004 01:12 AM
