Battery cables - Defender Source
Old August 17th, 2013, 12:28 PM
jijalicious
Jiman Khosravan
'94 D90
Battery cables
Morning gents
Got more gremlins...
I Move the battery around and power flickers. Deciding to change out both cables that connect to the battery.
Haven't looked underneath... Any one can describe the process of replacing them? And any have the part numbers and where to get them?
~jij
Old August 17th, 2013, 12:50 PM
Jiman, you will want to make your own or have some custom made to length. Primarily because if you are going to do this you are better off using thicker cable. The ground cable is short and routes to the transmission/transfer case and then the frame, or visa versa. The positive cable is longer and goes to the starter. Get the right sized end lugs to match the bolts and whatever battery ends you like (lots of options and you can get ones to allow adding additional cables for fuse blocks, accessories etc.).
Originally Posted by pendy
I'm here for the D's
Old August 18th, 2013, 07:48 PM
atlcruiser
david
many
Hate to jump in and pimp but these are the mac daddy
Available for Petrol or diesel
http://www.urbanlandcruisers.com/sho...attery-cables/
Terrence Anderson
Shipping Manager
URBAN LAND CRUISERS LLC
+44 404 915 1281
Atlanta, GA USA
URBAN LAND CRUISERS + ROVERS LTD
1st Floor, 2, Woodberry Grove
London
N12 0DR
UNITED KINGDOM
+44 020 8133 1557
Company Registration No. 09003009
Our new Vehicle Sales site:
Old August 18th, 2013, 10:24 PM
You should check the torque on the ground cable at the frame and at the transfer box, both of mine came loose at separate times.
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Upgrading Battery Cables - Lengths? priest944 Defender Technical Discussions 0 January 7th, 2009 06:59 PM
How does everyone route their winch cables JackW Defender Technical Discussions 10 September 12th, 2008 11:15 AM
Replacing Battery Cables mikeybob2@msn.com Defender Technical Discussions 5 June 2nd, 2007 11:22 PM
