Battery cable size - Defender Source
Old June 1st, 2010, 11:16 AM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Battery cable size
What size cable is everyone running from the battery to the starter on a 200Tdi? I always think bigger is better and got 2/0 but it seems pretty big. It's a 4 ft run from the battery box to the starter. Also I got an 870 CA Optimum yellow how does that sound?
Old June 1st, 2010, 11:36 AM
I think stock is 1 gauge. 2/0 is a good choice. If you use welding cable, it is MUCH easier to work with....than automotive cable.
Of course, I've never had a problem cranking, even at -40 with the stock cables..
Old June 1st, 2010, 01:36 PM
John,
On a sidenote, I am VERY interested to hear what issues you have in a TDI Defender in -40 weather, and how to mitigate them.
Old June 1st, 2010, 03:12 PM
No problems. Just make sure you have a good battery. You should run a good synthetic oil to help starting flow.
I have a Webasto now, so try and and avoid deep cold starts, but it still works without it.
Old June 1st, 2010, 08:32 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Assuming the starter draws 250amps, which I'm guessing is being very liberal, #1 would give you a volt drop of 0.3v, or 2.5%, which is within acceptable limits.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 1st, 2010, 10:37 PM
I have dual isolated batteries, a webasto thermotop c and run mobile one turbo diesel. anything else, or am I set?
Old June 2nd, 2010, 12:23 PM
Sounds good. Can't hurt to run some diesel fuel conditioner (with anti-gel) especially if you are not sure of the fuel source or if you buy it in a warm region and drive to a cold one.
What are you using for gearbox oil?
battery
Source for #2 Gauge Battery Cable Firemanshort Misc. Chit-Chat 7 July 27th, 2009 02:47 PM
Factory Battery Cable Guage javelinadave Defender Technical Discussions 8 March 8th, 2005 05:13 PM
