Battery Box Cleanup - Defender Source
Old May 14th, 2009, 09:34 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Battery Box Cleanup
I swapped out the 9 year old Interstate today and noticed quite a bit of surface rust in the battery box.
I'm looking to wire brush as best I can then add a coat of POR-15. The J-Bolts still look solid but are rusty so I'll order some replacements.
BTW, I went with a DieHard Platinum 31 Marine version. From some of the threads on ExpeditionPortal it is very close to the Odyssey 2150 but at least $100 cheaper and on the shelf at the local Sears. Wondering if anyone has used one. My plan is to use one big battery vs 2 smaller as the stock sized Interstate has lasted so long.
If anyone has any other ideas please let me know. Would like to get it cleaned up in there. Thanks!
Old May 14th, 2009, 09:51 PM
Drill out all the rivets, have it blasted and galvanized and then re-rivet it on.
Old May 15th, 2009, 10:18 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Damn, that does sound pro but might be a little more work than I was wanting to do.
When I was searching for the J-hooks I came across this last night: http://www.roversnorth.com/store/p-4...der-90110.aspx - could blast and have that galvanized to keep the downtime low.
Old May 15th, 2009, 11:34 AM
That would be even better.
Old May 15th, 2009, 12:41 PM
There is a place in the UK that makes aluminum battery boxes. A much better idea, IMO.
http://www.yrm-metal-solutions.com/page2.htm Around $100 plus shipping. They are supplied in pieces, so ship flattish.
Or you could make your own from some aluminum sheet. Pretty straightforward.
Old May 15th, 2009, 12:55 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
John D.,
They seem like a better solution & more sturdy also.....I will give some feedback on this next month since thats when I will replace my battery box...it rusted thru & my "OPtima" battery might just fall thru the hole any day now.
battery
Battery Box Replacement? IPSC_GUY Defender Technical Discussions 12 December 23rd, 2009 09:16 AM
Waterproofing speaker box? Helihntr Defender Technical Discussions 9 May 26th, 2005 12:31 PM
Sealed battery? OCD90 Defender Technical Discussions 4 December 22nd, 2003 01:43 PM
