basic questions - Defender Source
Old August 8th, 2011, 06:20 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
basic questions
Hello,
Most people on this forum have seen these questions probably a thousand times. So sorry for this.
But I was servicing my LR 2.5 engine and I was wondering what kind of oil I should use to replace the old one.
And unfortunately I don't have any experience with cleaning an oil bath air filter. How exactly should I do this?
Old August 8th, 2011, 06:22 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Petrol or Diesel?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 8th, 2011, 06:24 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
its a 2.5 NA diesel
Old August 8th, 2011, 06:43 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I use Shell Rotella 10W-40W in both my diesel Land Rovers - Walmart carries it
Old August 8th, 2011, 09:59 AM
Antichrist's Avatar
Antichrist
Tom Rowe
x2 on the Rotella. For many years I used Dryden/Castrol Dieselall, but that's been hard to find close and I've switched to Rotella.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 9th, 2011, 08:24 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
rotella it is! thanks!
Old August 9th, 2011, 11:48 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Originally Posted by belgian View Post
Hello,
I think everyone has given you advice for the engine oil, you just need cheap oil to fill the oil bath filter.
I'm surprised that a 110 has an oil bath filter, maybe it was a camel trophy thing.
I'd empty the oil out of the filter, rinse the gauze filter and oil pan with diesel drain and refill with cheap engine oil. You don't need fancy stuff in the filter, it just has air drawn through it and the dirt trapped in the gauze which drains back into the pan and settles to the bottom when the engine is off.
Mike Hammond
300tdi Basic Questions - Now With Underdrive! AfricaOrBust Defender Technical Discussions 6 February 13th, 2009 07:07 PM
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
