Bar's Stop Leak - Defender Source
Old July 7th, 2007, 10:12 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Bar's Stop Leak
Three months ago I replaced the head gaskets, and recorred the radiator on the D110. Today I noticed a coolent leak from the rear. The leak does not appear to be from the head, but maybe between the transmission and the motor, behind the starter. Last month I removed the heater core because it was leaking (AC works now!). The temp per infrared gun says 185 at the temp sender.
I was wondering what everyone thought about using Bar's Stop Leak to cure this. I hear only mixed reviews of this stuff. I think a small does would do the trick without any ill effects.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old July 7th, 2007, 01:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Uh oh. Sounds like a freeze plug might have gone out on you. And not in a good spot either, since you can't access it without pulling either the engine or the transmission. The stop-leak may or may not work, depending on how bad the leak is. But worth a try, as opposed to the other solution.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 7th, 2007, 04:51 PM
Jon_Winningham
Sterling M Archer
Fill Tower Cap
I traced the leak to the fill tower cap. I must have over tightened it when I bypassed the heater core. Luckily I always keep a spare one.
Thanks Hans, that would have been my next check...
None the less, this may be a good discussion on whether to us Bar's Stop Leak for future reference.
Old July 7th, 2007, 07:57 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I have used ceramic block sealer in the past on 4.0 L disco that had porous block. It worked for a while but eventually the motor had to come out.
So I guess it depends on what the issue is. It would be worth keeping a can of it in the boot in case you are out on the trail and need a short term fix.
mantec roof bars w/sd basket? steved90 Defender Technical Discussions 0 November 23rd, 2005 12:08 PM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
