Banging Noise - Defender Source
Old February 22nd, 2007, 01:01 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Banging Noise
I have searched and found some great info, but wanted to post also for some feedback. Just recently replaced the stock driveshafts with custom tom woods double cardan shafts and just replaced motor mounts and tc mounts. Used the qt service mounts for the motor, stock rubber mounts for tc.
Prior to these updates, had a metal vibration type sound appear when motor/exhaust/etc. reached normal temp. Happened during deceleration at stops. Thought maybe a cat was going bad. Since these updates, have a banging clanging noise when decelerating and accelerating. Kinda sounds like the driveshaft is banging the crossmember or something. Inspected, didn't notice anything of the sort.
This is really weird. Wondering if it could be since the driveline angle has been kinda bad, with the stock shafts and 3"lift, that by allieviating this with the double cardan shaft it released some sort of failure in the tc or transmission? Bearing?
Anyone experience a similar issue with brand new double cardan shafts with brand new spicer u joints? Is there a "break in" period that may cause this banging noise?
Any advice would be appreiciated.
Old February 22nd, 2007, 03:50 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
There are a lot of unrelated things that can cause those noises. For instance, I had a very worn-out steering joint that allowed a lot of the longer steering rods too much clearance, resulting in a bonking sound when accellerating, shifting and stopping quickly.
Other folks have had similar sounds coming from worn out suspension bushings.
The stock style cats have a tendency to break apart internally sometimes, which causes rattling noises at times.
I'd start by just getting under there when the truck is cool, grabbing various things and giving them a good shake.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 22nd, 2007, 04:15 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would start by checking the frame-to-trailing arm bushing and frame to radius arm bushings as well as your rear A-Arm joint. Since you are referring to accel/brake occurances, these make most sense to me.
Old February 22nd, 2007, 09:06 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
x2 check your bushings....
Are you refering to the slack in the drivetrain?
How loud of a "bonk"?
Old February 23rd, 2007, 12:02 PM
kiefffff's Avatar
kiefffff
Keith Rider
I plan to get under it tomorrow and shake some stuff around. I'll check the bushings too. The rear links are new, so hope those aren't bad already. Could be the front radius arms. Those are still stock. Its just kinds weird that it was not there prior to mounts and shafts, then bang!
It sounds like someone taking a hammer and hitting the frame. Would this start in the drivetrain after double cardan shafts allievate angle issues?
Old February 24th, 2007, 11:17 PM
kiefffff's Avatar
kiefffff
Keith Rider
Well, checked everything. Seems fine. Drove around and the clanging noise still there. Think either new u-joint bad or transfer case. Really strange. I am baffled.
Old February 25th, 2007, 01:06 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Did you check the A-arm ball joint? If so, how did you check it?
Old February 25th, 2007, 07:28 PM
kiefffff's Avatar
kiefffff
Keith Rider
Visually checked it and grabbed it to see if it was loose. Seemed okay. Is there another way to check it? Clue me in.
The clanging noise seems to occur when rpms are around 2000 and decelerating. Its like a bonk, bonk, bonk, as the driveshaft comes to a stop and is rotating. May be out of balance or input/output angle issue?
Old February 25th, 2007, 08:17 PM
Hans's Avatar
Hans
Hans Haase
Might also be a bad U-joint, they can be deceptively hard to diagnose. To really check them, you need to chock the rear wheels and put everything in neutral. Otherwise, because of the location of the parking brake, the tension on the driveshaft can make them SEEM solid even if they are about to collapse.
-Hans
My oil line fix
Old February 25th, 2007, 09:48 PM
kiefffff's Avatar
kiefffff
Keith Rider
These are brand new. Guess there could always be a bad one.
Old February 28th, 2007, 01:08 PM
kiefffff's Avatar
kiefffff
Keith Rider
Some friends of mine think it is coming from the transfer case. Anything in there that could be causing this noise?
Old March 2nd, 2007, 01:26 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hand brake shoe?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 3rd, 2007, 06:01 PM
kiefffff's Avatar
kiefffff
Keith Rider
Checked the hand brake shoe. Its okay. 95% sure its the Transfer Case. Time to think about options of repair. Its getting worse eveyday.
Old March 4th, 2007, 01:27 PM
kiefffff's Avatar
kiefffff
Keith Rider
What are the options for the transfer case? Places to buy or rebuild? What have all of you done that had tc issues?
Got under truck again with it running and can hear a grinding type noise coming from the case. It may "explode" any day! My guess is that previous owner mechanic rounded off the fill plug on the transfer case. Last time oil was replaced, had to fill thru sensor. Done by dealer. My guess is that the gears are worn out due to abuse and since the drivetrain geometry has been corrected with new motor mounts and trans mounts, and new shafts, new diffs, etc., the bearing is bouncing around in the case and gear wear is more evident. Hope this diagnostic is correct! Sounds good anyway. Thanks for all of your suggestions.
Old March 4th, 2007, 01:48 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
New or reman for George
Jimmy Buffett
Old March 4th, 2007, 02:04 PM
Hans's Avatar
Hans
Hans Haase
Well, I also suggest checking if it's the "Clunk of doom" before ordering a transfer case. It may actually be the transmission output shaft wearing out, which extends into the transfer case. This would mean a new transmission, but the transfer case would be fine still.
Thankfully, that can be checked without much hassle. You just need to remove the PTO cover from the transfer case and the input gear will slide out for inspection. There are a few good websites that covert the problem, I'll see if I can dig them up later.
-Hans
My oil line fix
Old March 4th, 2007, 07:17 PM
kiefffff's Avatar
kiefffff
Keith Rider
Thank you Hans. Will need to check that too. Can you explain how the dealer refilled the transfer case through the sensor? I would need to do the same since the fill plug will not come out. If it is the transmission output shaft, how long will it last before it goes? I may have multiple issues going on, which may result in both the transmission and transfer case. That would really suck.
Old March 4th, 2007, 11:31 PM
Hans's Avatar
Hans
Hans Haase
Refilled through the sensor? Maybe he removed the speedometer cable and filled through there? He would have to use one of those syphon tools, I forget the correct name.... it looks like giant syringe but with a flexible tube instead of a needle... I got mine at Napa.
Anyways, the output shaft could last months if you baby it (and if it IS actually a problem), or it could go anytime. Most people that had it go bad say it just goes out on them suddenly with no real warning, just CLUNK and the truck don't move anymore. But because the output shaft from the tranny goes really far into the transfer case, the problem will sound like it's the transfer going, even though the part that is failing is part of the transmission.
-Hans
My oil line fix
Old March 5th, 2007, 12:29 PM
kiefffff's Avatar
kiefffff
Keith Rider
Can the shaft be replaced with the transfer case removed, or do you have to drop the transmission too? All I see are $$$$.
Another question, if one or the other or both need replacement, would you deal directly with Ashcroft in England or would you work through Atantic British or Rover North type outfit here in the states? Any cost savings? Thanks again for the feedback.
Old March 5th, 2007, 12:34 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Is that shaft a common problem on the 90's? I thought they addressed it in the 90's by adding an oil passage and that it was only really a problem on the '93 110's. I'm intrigued now...
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
now... a loud squealing noise... norros Defender Technical Discussions 2 May 3rd, 2005 09:58 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
