Banging Noise - Page 2 - Defender Source
Old March 5th, 2007, 01:01 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
The shaft was an issue on the earlier 90's with the LT-77's as well, and not all of them got the retrofit parts. I've also heard that in some cases the LT-77's were replaced with R-380's under warranty.
Unfortunately, replacing the shaft means tearing down the transmission. But it is possible that it's already been repaired/upgraded, which is why you need to check before spending money on replacing the whole transmission.
You also mentioned that you need to replace the transfer case, what's wrong with it? They are usually one of the more durable parts of the truck.
My oil line fix
My 100k stopped odometer fix
Old March 21st, 2007, 02:09 AM
01001010's Avatar
01001010
JC Alvarez
1996 Discovery SE
Any updates?
Previous Rovers
1996 Discover SE
1965 Series IIa 109'
1965 Series IIa 88'
Old March 21st, 2007, 12:56 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Just want to say thanks to all for the help. Under advice from Steve and Drew at Rovertym, I re-checked the rear pinion angle again. Took all the spacers out of the Rovertym rear links. So far, the banging, clanging noise I was hearing has gone away. The other noises, playing card in bike spokes, etc, are still there. My guess is tranny output shaft or TC input. At this time, plan to ride it till something breaks or gets to the point of having to replace. Hope it doesn't happen on my way out to Utah next year!
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
now... a loud squealing noise... norros Defender Technical Discussions 2 May 3rd, 2005 09:58 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
